Correct way to clear OBD1 codes ?
Old Apr 8, 2017 | 06:04 PM
NICKSAN's Avatar
NICKSAN
E-150, 5.8/351
The Haynes manual says not to disconnect battery (for whatever amount of time) to clear codes because it also clears the keep alive memory forcing the computer to relearn.
What is the correct way to clear codes?
The manual says talks about jumping the OBD connectors some way but I cannot tell what is showing in the picture.
Thanks.
Old Apr 9, 2017 | 07:22 AM
Franklin2's Avatar
Franklin2
I know of no other way to clear the EECIV codes other than taking the negative battery cable off for a period of time.
You should already know the codes in memory, and if you have repaired something that was throwing a code, you do want it to relearn now that you have it fixed. It will run a little weird for a day or so till it does relearn certain sensors.
Old Apr 9, 2017 | 07:25 AM
Franklin2's Avatar
Franklin2
P.S. I did hear that you can get setup with the jumper and let it start spitting codes, and then unplug the plugs in the middle of it sending codes and it will reset it partially. You can try that, I have never done it before.
Old Apr 9, 2017 | 07:39 AM
EPNCSU2006's Avatar
EPNCSU2006
Disconnecting the jumper while it is blinking codes will reset the codes, but will keep the learned adjustments.
Old Apr 9, 2017 | 08:13 AM
projectSHO89's Avatar
projectSHO89
This is the correct procedure for clearing the fault codes (only).
If you don't care about the relearn procedure (it's not a big deal, the computer will do it automatically), you can indeed just pull the either the negative cable or the fuse for the PCM's KAM (if implemented).
Old Apr 9, 2017 | 11:51 AM
NICKSAN's Avatar
NICKSAN
What blinking? on my code reader?
Thanks.
Old Apr 9, 2017 | 11:53 AM
Franklin2's Avatar
Franklin2
Thanks.
He is talking about using the dash light or a testlight to read the codes, and it flashes the codes. You do not need a code reader to read the codes on these old computers. Unplugging the small plug on the code reader while it's giving codes should do the same thing.
Old Apr 9, 2017 | 12:31 PM
NICKSAN's Avatar
NICKSAN
Oh, the dash light.
I would think that unplugging it while in process would damage something.
Thanks.
Old Apr 9, 2017 | 02:02 PM
projectSHO89
There are OBD-1 code readers out there. Some are simple adapters with a switch and an LED that do the same thing as a jumper and the CEL. There are others that read the "fast codes" that are sent out before the slow flash sequences.
Depend on what he's got.
Old Apr 9, 2017 | 04:33 PM
Franklin2's Avatar
Franklin2
Oh, the dash light.
Thanks.
No, you unplug the small plug under the hood that starts the code retrieval process, not the light.
Old Apr 10, 2017 | 07:56 PM
NICKSAN's Avatar
NICKSAN
Yes, the code reader.
What I meant was I would be afraid of damaging the code reader or the ECU by unplugging the reader while in the middle of testing.
Jules3084
Jun 13, 2011 11:32 AM
freegdr
1997 - 2003 F150
Feb 6, 2011 06:13 PM
kools20
Bronco II
Jul 22, 2008 07:06 PM
choppersinc
1983 - 2012 Ranger & B-Series
Mar 1, 2005 08:29 PM
