New headers
Old Apr 8, 2017 | 05:36 PM
Anthony79's Avatar
Anthony79
New headers
So awhile back I posted a thread about liquid metal on headers . What a waste of time. so I bought some new one from summit racing. My question is when I but the new ones on do I use anti seize on the threads of the bolts?
Old Apr 8, 2017 | 05:42 PM
jakeharp's Avatar
jakeharp
Yes
Yes .... Solid yes on this.... I used permetex copper anti-seize .... Also do yourself a favor and grab some quality header gaskets... I used RemFlex, they are collapsible aluminum crush gaskets.... I did have to re torque once, but no leaks after that..............which is remarkable for an FE engine...
Old Apr 8, 2017 | 05:59 PM
Anthony79's Avatar
Anthony79
The header came with some gaskets. They claim they are a good quality gasket do I trust them?
Old Apr 8, 2017 | 06:07 PM
jakeharp's Avatar
jakeharp
Your call
Chances are they are thin cheepo gaskets, thats what came with my Flowtechs, I bit the bullet on a set of RemFlex after reading lots about the different options... Im no expert either, yours may seal just fine... How are your mating surfaces, obviously your headers are new, so that's a non issue, how bout the heads at the exhaust ports ? if you got them nice and pretty with a grinding brush or whatever and they are smooth, even and no pitting, than you may be ok.... If your dealing with pitting, old gasket material burned into the cast iron, then you may want a thicker crush gasket, but also not the end of the world if you want to try out the included gaskets, re-torque after a few HOT runs on the motor and see how they seal..... Good luck...
Old Apr 8, 2017 | 07:07 PM
Anthony79's Avatar
Anthony79
Thanks again, Sounds like I may need look in to some good gaskets. I just looked at my and there pretty thin.
Old Apr 9, 2017 | 08:38 AM
good to doo's Avatar
good to doo
How thick are the header flanges? That makes a big difference in weather they stay tight or not.
Old Apr 9, 2017 | 08:46 AM
shocker998md's Avatar
shocker998md
remflex is all that I use now.
Firefighter12
Aug 1, 2019 08:22 PM
steuben
Nov 28, 2008 10:25 PM
OrangeJuice
Mar 25, 2008 09:03 PM
jowilker
26
Oct 13, 2007 06:02 AM
scamardo
21
Feb 18, 2006 05:41 PM
