I'd suggest RTV too - on top of whatever gasket you choose.
Weird, but what I did was use a set of 330 exhaust gaskets (included in the FE gasket kit for some reason), the ones with metal on one side, and some sort of clay on the other.
Opened up the exhaust holes just enough to match the headers, RTV'd both sides, let it skin (VERY IMPORTANT!) and installed them.
I was lucky, in that I already had the headers installed, so they were all aligned correctly and everything as I installed the gaskets. It's a real pain in the butt to do it with the headers loose and flopping around
That 330 gasket setup lasted for 15 years... When I pulled the engine out of the highboy, the RTV was still holding the headers to the heads - so much so that I needed a pry-bar to get them off...
So the set of exhaust gaskets with the aluminum on them were for a 330? My 66 had that on them so that what I used from the kit after the rebuild. Used hi temp copper gasket rtv as well. The heads were a little rough orund the flanges but not so bad that a gasket wouldnt do th trick. Thought about having them machined along with the manis but the 90.00-170.00 price tag snuffed that out... Planning to go with headers and dual whern the $$ is in hand so it would have been money pissed away really.
The gaskets I'm talking about had smaller exhaust holes than the standard FE exhaust gaskets. They also had a crossover in the middle - which I took to mean it was a 330 exhaust gasket since 330 was listed on the kit. OK, maybe it listed 361/359/391 too... According to the FT stuff we've talked about here, those gaskets are the right ones for any FT.
Anyway, those are what I used, as the FE gaskets in the kit had exhaust holes so big that the header flange would fall inside of the hole. They matched the stock exhaust logs, but not the headers ... even though the headers were big enough for the FE heads' exhaust ports.
I still have the leftover gaskets I'll have to have a closer look at things.
Joe, many posts say about any gasket (paper-hi dollar) works fine if the prep is done and the head/headers are in decent shape to mate up well. One thing I recall that made some sense was from (Putt) I think.. using studs with nuts/washers rather than standard header bolts/washers. Seemed like this would be much easier to fart with if needed be. The studs helped hold the gasket in position as well as the header while you manage the fit, reach for another nut/tool/beer etc..
I have used reusable copper gaskets before and found the holes didn't line up correctly as they should.
John
Look em up. Advance Auto used to stock the small block Ford and Chevy gaskets in the stores, last set I bought was from the local AutoZone. I've used two sets on small blocks and both fit perfectly.
Well it seems you obviously didn't notice we WERE trying to answer your original question. Sorry we let you down. Maybe you need to do more here an do the research we did.
John, my recommendation is for Victor Nitro-Seal exhaust gaskets, available from NAPA, CarQuest and likely others as well. If you slot the two end holes of the gasket on the bottom, you can start those bolts and then slip the gasket in place, install the remaining bolts and tighten them all up. Redmanbob, I don't think I suggested that use of studs, but I'm glad somebody knows I am here!!!
My bad bud, but the original post wasn't how many are available that I could search the net for, but rather,
"Any consensus on the better/best long term or reusable header gaskets, considering both gasket fit and port hole fit."
