6.4 turbo won't go past 20 PSI
6.4 with DPF delete, tuned
The turbos simply will not go past 20 PSI, no matter how hard I try. Additionally, travelling at high speeds for extended periods (70 MPH on the interstate for over an hour or so) causes the wrench light to appear. I'm thinking the big turbo isn't engaging and because the little one is trying to compensate it's overheating the oil, but I don't know.
Any advice?
Any advice?
Any advice?
Any advice?
Just wondering, if you are empty/towing or not, and what mpg you are seeing. We have a similar truck. I seem to be in the 12s at that speed.
I've replaced every filter on the truck other than the tranny filter, I don't tow with it because of the problem, and I've checked for codes with the wrench light on and nothing came up. My oil filters have been metal free as far as I could tell, I took the last one apart checking for metal bits and didn't see any.
My MPG is 13.2, according to the dash.
Since the last post I have gotten the turbo past 20 psi but it only went to the mid 20s while nearly flooring it. this was going on a flat road on the interstate without any weight in the bed or towing anything.
What did the fuel filters look like? Do you have a way to monitor the High Pressure Fuel Pump? I have an Edge Insight CTS. I can set it to monitor about any sensor on the truck. And it reads codes, and can reset them too.
How many miles are on the truck?
Any exhaust leaks? Broken manifold bolts? Up pipes to the turbos leaking? What about the pipes from the turbos to the air-to-air cooler and back to the intake?
P1000
It means the truck hasn't been driven enough to run all of the internal tests since the last time the codes were cleared or the batteries were disconnected. Disconnect both batteries, leave the cab door open to trigger a voltage drain, let the truck sit for twenty minutes before re-connecting the batteries, take the truck for a long drive like 1/4 tank.
P0480
Fan response is not correct, Check the wiring harness and the connections.
2008 Fan Clutch Wiring diagram
Pin #1 – Control signal – PWM signal which is hard to measure with a volt meter
Pin #2 – VPWR – 12 volts from fuse (F74)
Pin #3 – Ground
Pin #4 – speed signal back to PCM (feed back)
Pin #5 – VBPWR – power back to PCM
P0480
Pin #3 – Ground
blaksmoker
06-27-2007 07:09 PM
