When does the turbo kick in?
Old Sep 30, 2005 | 12:40 PM
qman's Avatar
qman
At what RPM does the turbo kick in? Is it around 2000? That's about where my truck gets gobs of power and I need to know if I'm flushing fuel down the drain.
Old Sep 30, 2005 | 12:59 PM
Kwikkordead's Avatar
Kwikkordead
Turbo boost is more tied to engine load than rpm. They spin even at idle. If you are concerned about fuel use, the best way to control that is with your right foot.
Old Sep 30, 2005 | 01:44 PM
qman's Avatar
qman
yeah, I do try to control the right foot. I know that when I gun it and get to around 2000-2500 RPMs, the sucker takes off like a jet. That's why i was wondering. I've read posts here where guys say they try to keep it under 2000 to keep mpg up. That's why I was asking.
Old Sep 30, 2005 | 03:35 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
the turbo can spin twice as fast at 1750 RPM with 100% load, than at 3000 rpm with just a slight load. exhaust flow controls the speed of the turbo. there isnt a switch that says "turbo on/off" as the exhaust passes through the turbo, it expands inside the chamber. then it has the compress again to go out of the turbo, and through the exhaust. this compression pushes angled blades axially as it passes out of the chamber, and this spins the turbo over. under load, the engine produces more exhaust, hence the more compression out of the chamber and into the exhaust pipe. this spins the turbo over faster= more boost. plus it produces that awesome whining sound.
Old Sep 30, 2005 | 07:23 PM
Hello's Avatar
Hello
At 2000 rpms I'm ready to rock n roll!
Just like a tea kettle near its boiling point and ready to whistle!
Danner717
Sep 20, 2015 08:48 PM
walksLikeBear
1983 - 2012 Ranger & B-Series
Jul 25, 2015 02:24 PM
peruexcursion2000
Oct 19, 2011 04:20 PM
granny_rocket
Mar 24, 2009 06:54 AM
brabe
Oct 30, 2003 10:12 PM
