Sponsored by: Real Truck
Mileage
Old Apr 7, 2017 | 04:27 PM
nick2064's Avatar
nick2064
Mileage
Hey all, I have a question. I have a 2004 F250 superduty 4door longbed 6" Fab tech lift running 31.5's(35") tires, with the V10. I don't believe the gears were changed, I believe from the tag on rear diff it's still running 3.73.When I bought it, the overhead console MPG said 14.1 ever since then it went down and now I can never get it above 8.0MPg. Did the previous owner do some trickery to get it to read that high?
Old Apr 7, 2017 | 04:46 PM
Misky6.0's Avatar
Misky6.0
It all depends on type of driving.
I got 14 mpg with my '99 f350 v10 last fall on the secondary hiway, 60 mph cruising back-n-forth 2 hr each way to/from train station picking up/taking back family for Thanksgiving. If you do stop-n-go city it will be less. Interstate, driving 80mph different again. If you always pin the gas pedal to the floor it will be even worse.
It is an 8K lb brick, for hauling or towing stuff.
Old Apr 7, 2017 | 04:53 PM
seville009's Avatar
seville009
It's easy to trick the console....just reset it while you're coasting, drive slowly into your driveway, and shut the engine off. It will go back down quickly though to normal once you start driving.
Old Apr 8, 2017 | 07:07 AM
I.B. Washincars's Avatar
I.B. Washincars
Yep, just reset it before you go on one of those long interstate drives and drive like there's an egg on the pedal. Your mileage will reflect what you average after the reset. It will creep back down as you go back to your normal stop-n-go routine.
Old Apr 8, 2017 | 11:10 AM
RainDesert's Avatar
RainDesert
I'm not sure what tires were sent with your truck from the factory, but with 35's your speedo is off around 5% to 10%. To accurately calculate your mpgs you need to know how far you are actually traveling vs the odometer.
Ford554
Jan 18, 2009 01:15 AM
FordtruckBoy13
Modular V10 (6.8l)
71
Oct 27, 2006 01:39 PM
swheeler
Modular V10 (6.8l)
Sep 23, 2004 01:41 AM
greghoffmann
Sep 13, 2002 11:05 AM
Redv10
Modular V10 (6.8l)
42
Jun 19, 2002 04:46 PM
