Modular V10 (6.8l)
Stalling help
Old Apr 7, 2017 | 01:28 PM
tarditim's Avatar
tarditim
Stalling help
Stalling help
So to start with simce january ive put 8 pumps in my truck (01 f550 with 6.8 v10) 6 were burnt up due to low voltage. Repaired wiring all was good. The other 2 were due to a failing fuel tank liner. I replaced the tank and went to start the truck and it would start and run for a minute then die. Fuel pressure test shows 20psi then drops off (obviously low) i tried a couple new pumps with no change. (The fuel pump relay, inertia switch and fpr are all new). When it starts if i hit the gas it immediately dies off....does anyone have any ideas? Its not a fuel pump electrical fault as i have good power througgout the crank and start.
Old Apr 7, 2017 | 07:08 PM
z31freakify's Avatar
z31freakify
Dumb question but did you replace the fuel filter again? Maybe with the delamination the lines got plugged up? Apply compressed air on the fuel line to tank just too rule that out ( make sure the fuel pump is not connected to the fuel line.
Old Apr 8, 2017 | 08:37 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
If the tank delaminated, maybe the fuel lines are degraded too?
Old Apr 15, 2017 | 10:36 AM
'88 E-350's Avatar
'88 E-350
With the engine off does it make proper pressure and stay pressurized after turning the pump off? If not I'd be looking at the FPR.
tarditim
Apr 8, 2017 04:59 PM
tarditim
1997 - 2003 F150
Apr 7, 2017 12:50 PM
DrFord
Oct 20, 2013 09:46 AM
sccaracer
Oct 8, 2013 10:06 PM
cyclist7531
1983 - 2012 Ranger & B-Series
Apr 29, 2011 11:22 AM
