How to....?
Old Apr 6, 2017 | 11:37 AM
Russ74's Avatar
Russ74
How to....?
How do I get this boost valve out of my C6 valve body so I can replace the springs behind it? I have removed the cover plate. Valve won't budge.
Old Apr 6, 2017 | 12:04 PM
F250_Super_4X4's Avatar
F250_Super_4X4
Normally it pops out due to spring pressure which tells me you probably have a broken spring. if Im not mistaken the spring is exposed on the reverse side? You may have to drill and tap the pressure boost valve, not the sleeve, insert a screw and pull it. Make sure to look for damage inside the bearing surface, may require a new valve body.
Old Apr 6, 2017 | 12:32 PM
Russ74's Avatar
Russ74
yes, reverse side is exposed. Revealing the springs. They appear to be in tact. The valve moves back and forth as it should. I can use a screwdriver to gently pry on the back end of the valve and get it to push the sleeve out about 1/8 of an inch. But then it's like it jams and won't move any further.
Old Apr 6, 2017 | 02:57 PM
fordguy2100's Avatar
fordguy2100
I have like 10 c6 valve bodies if you run into troubles and need another one
Old Apr 7, 2017 | 01:04 PM
F250_Super_4X4
Seems that the pressure boost valve and/or sleeve have dug a valley into the bore. Similar to removing a U-joint try to grab onto the sleeve and twist a bit. I'm 90% sure the bore is shot at this point of which you can re-bore and get an oversize kit or (my recommendation) you can just get a new valve body.
Jam Ras
Feb 2, 2017 09:37 AM
Tugly
18
Aug 25, 2016 06:35 AM
89ford73
Sep 19, 2010 02:01 AM
Fords&Farmalls
Jun 19, 2007 09:13 AM
MercM47
Oct 24, 2003 11:57 AM
