Valve Cover Issues on 460
Hey all! I recently replaced my intake manifold and in the process replaced the gaskets on the valve covers. They are the original covers and didn't leak before, but now I'm getting leaks and spray from the bolts that hold them down. Not all the bolts, just some.
At high RPM oil is coming out from under the bolts and even out from the breather. I think the breather just needs to be replaced, and the PVC valve in the back always got a little film around it, but the bolts never leaked. Any suggestions? User error?
I'm going to remove the covers and make sure the flanges aren't bent. I'm also going to buy a baffled adapter for the breather. It's currently just a rubber gasket. I'm probably going to buy some hold downs to spread out the tension of the bolts too. I just thought it odd the oil was coming from the bolts themselves and not the underside.
Also, remove the valve cover and check to see that there is a shroud over the PCV port.... all it should suck is air. It should be shielded from the oil splash created by the rocker arm action. Any while there verify that the drain back holes are clear.
Just an interesting tid bit.... some NASCAR race teams allow oil to almost completely fill the valve covers to immerse the valve train and maximize cooling of their dry-sumped system, 9800 RPM engines.
queen of spades
11-16-2013 05:30 PM
71FoMoCo
06-05-2003 05:34 PM
