Shift kit help!
Old Apr 5, 2017 | 09:25 PM
Russ74's Avatar
Russ74
Shift kit help!
1974 C6. Bought a TCI shift kit that I'm trying to install. First time doing this myself. I have the valve body out and separated. The first part to replace is the outer pressure regulator spring. I have the front plate off of the pressure regulator but IT WONT COME OUT! Am I missing something? How do I get the pressure regulator out to change the spring?
Old Apr 6, 2017 | 11:17 PM
jk080's Avatar
jk080
Transmission Rebuilder
72 and earlier have a plate over the valve, 73 and later have no plate, it has a thin clip that holds the valve in.
Which one are you dealing with?
If you have the plate you may have to use a pick or something to carefully pry out the valve train.
Name:  c6 PR VAlves.JPG
Old Apr 7, 2017 | 04:31 AM
Russ74's Avatar
Russ74
It's a 74 but it has the plate. I was able to pry it out.
Russ74
Apr 5, 2017 09:01 PM
Russ74
Apr 5, 2017 07:45 PM
meborder
Oct 18, 2013 04:48 PM
FordYoungGun35
Oct 18, 2013 04:08 PM
whybnormal
29
Jan 25, 2007 08:36 PM
