steering wheel tilted by itself??
Old Sep 1, 2003 | 12:11 PM
sail2244's Avatar
sail2244
Question steering wheel tilted by itself??
I just purchesed a 1984 F150. The truck had been converted from an automatic to a standard transmission. It had a C6 automatic but now has a 4 speed overdrive transmission and a 351 engine.
after driving it a few blocks I was stopped at a light and was trying to adjust the seat position I pulled on the steering wheel
for leverage and it came down into my lap. It still worked so i drove it home like that. But i cant seem to get it to go back up.
Anyone know what i need to do to get it back in position. ??
Old Sep 1, 2003 | 09:05 PM
1987LTDmasta's Avatar
1987LTDmasta
have you tried pushing the turn signal lever towards the speedometer? that should free up the wheel when its held down. let go and the wheel should lock in place.
Old Sep 4, 2003 | 01:14 PM
sail2244's Avatar
sail2244
Thanks this worked fine. I have another 1984 F150 and owned it since 1986 and my steering wheel never tilted so i dident know about this feature. Thanks for the help. You just don't know what you don't know.
Old Sep 4, 2003 | 02:10 PM
Rick_Ford's Avatar
Rick_Ford
I had the same problem. Took me a while to figure out.
Once I ran into it, all last winter it would pop out of joint sometimes just going down the road with the weigh of my hand on the wheel.
After the weather warmed up, it doesn't seem so easy to do any more.
I'm hoping when it gets cold again, it doesn't start happening again.
I don't want to have to get in there an fix it.
Old Sep 4, 2003 | 04:04 PM
Lessica Jake's Avatar
Lessica Jake
mine does as well, as far as i can tell, mine is a result of people using it to pull themselves into the truck. i've managed to find the limit of pressure i can put on it without making it fall, and i dont generally have a problem anymore. makes for good entertainment when someone else drives my truck though.
Old Sep 4, 2003 | 04:29 PM
Rick_Ford's Avatar
Rick_Ford
lol Yeah you should have seen my wife's face the first time mine popped out of joint just driving down the road.
HillBillyBuddha
Nov 2, 2013 05:10 PM
benbuilder
Jul 4, 2013 01:11 AM
sbriske
1997 - 2003 F150
Nov 10, 2009 09:21 PM
Myfreeford
Jun 19, 2007 06:01 PM
1990F250LB
Sep 5, 2004 09:36 PM
