Won't Start unless steering wheel turned
Old Sep 5, 2004 | 01:55 PM
1990F250LB's Avatar
1990F250LB
Hello,
I purchased a 1990 F250 XL Super (7.5 engine w/ automatic transmission) with a long bed yesterday. The starter switch seems to be spent, as it won't spring back into position, and the starter will not turn unless the Steering Wheel is in the exact same position every time.
I can turn the switch to "start" and then simply turn the steering wheel around until I find the "sweet spot". The starter will crank, engine will fire up, and I'll turn the steering wheel out of the "sweet spot" to shut down the starter. Then I'll turn the key back into the run position.
Heck, it works, but I'm worried this is a problem that will only get worse.
I've searched your prior threads here on the site, but have not seen this mentioned before.
Does anyone have any ideas, and a clue on how to fix this?
Thanks!!
JC
Old Sep 5, 2004 | 03:41 PM
91f250460's Avatar
91f250460
I would replace the column lock cylinder as it is bad. But as far as turning the steering wheel to start the truck that shouldn't affect starting as all the components are below the wheel. The only thing I can think of is the ignition switch, the one on the column under the dash(not the key switch) is going out. And by turning the wheel it is moving the rod just enough to hit the start position on the switch. Next time you try to start the truck see if you can't manually move the rod and see if that starts the truck. You should be able to get to it without taking the column apart, if not take the dash panel off under the wheel and there is a shroud, remove it to get to the rod.
T. Roberts
UFD Local 1147
Old Sep 5, 2004 | 03:47 PM
1990F250LB's Avatar
1990F250LB
Thanks for the information. I'll search the threads for step by step information on replacing the column steering lock, and the ignition swith.
JC
Old Sep 5, 2004 | 09:22 PM
beaker420's Avatar
beaker420
Ive never had my actual truck column apart but on any car I've ever worked on there is no spring in the lock cylinder. All the springyness is in the ignition switch and its connected to the lock cylinder with a metal rod. I'd just goto the wreckers and grab a new ignition switch. It might be held on with dumb screws that have to be drilled out.
Old Sep 5, 2004 | 09:36 PM
91f250460's Avatar
91f250460
Ignition switch is screwed on. You have to drop the column to get to it. It really isn't that hard to replace. The new switch will come with directions on what position to have the key in when you put the new switch in. There is also a little play on how the switch screws on the column(you can slide it up or down the column a little bit to set it properly.) Sounds like a lot harder job than it is. I replaced both the switches in my 91 in about an hour and two beers.
T. Roberts
UFD Local 1147
Cahlager
24
May 11, 2020 01:15 AM
shadetree enthusiast
Sep 18, 2014 03:39 PM
samahi72
Nov 3, 2013 11:04 AM
mounddog
20
Aug 9, 2008 09:31 PM
Stephen_E
May 9, 2004 01:50 PM
