NP205 Question
Old Apr 3, 2017 | 09:42 PM
ClintonA's Avatar
ClintonA
NP205 Question
I noticed my bushings on the mounts were squeezed out. So I dropped it, put new ones in and reinstalled the transfer case. Now I have an insane rumble out of the front shaft that goes between the transfer case and the C6 transmission where I never had any there before.
I took the shaft to a drive line specialist and he said my angles may be off, and not being an expert myself, I didn't think about they have to be plumb and parallel. I start shimming the back of the case and got rid of about 75% of my rumble. I am like jacking up the rear end, loosening it and moving it a little then running the drive line to see its movement like 20 times.
Is there an easier way than what I am doing? Any reference points I can measure? I am trying to get rid of 100% of it like it was before I messed with the transfer case.
Thanks!
Old Apr 4, 2017 | 06:55 PM
ClintonA's Avatar
ClintonA
So I jacked around with it today, I ended up shimming the the back of the brackets an inch and an eighth and replaced the bolts with longer ones.
The rumble is almost gone, but I am weary of shimming it anymore, any ideas what my real issue is? This is definitely not a proper fix.
I mean literally there was not a noise or rumble before I dropped my transfer case. I went ahead and replaced all the u-joints on all of the drive-shafts, no change.
Old Apr 4, 2017 | 08:14 PM
mark a.'s Avatar
mark a.
Something is either not put back together right or you got the wrong parts. I look at it this way, it wasn't like that before so what has changed? it was taken apart and parts were changed so your problem lies in there somewhere.
ckutter
Dec 29, 2014 07:58 AM
blk88notch
Jan 11, 2011 08:16 PM
mrhooie
Nov 9, 2009 05:19 PM
FordMan2
26
Dec 24, 2007 12:24 PM
$Simpleman76
Apr 14, 2007 11:50 PM
