Sponsored by: Auxito
Need help with rear end
Old Apr 7, 2017 | 10:11 PM
steve(ill)'s Avatar
steve(ill)
im not sure what the spec is on the F150, but I did an 8.8 inch in the Explorer and the spec was 25 inch pounds..... I used a 2 pound weight on a 12 inch wrench to check 24 ft pounds ROLLING RESISTANCE... it takes slightly more than that to START getting it to move.
Old Apr 7, 2017 | 10:18 PM
70f100longbed's Avatar
70f100longbed
The spec is 16-29 in-lbs IIRC so 60 will be way too tight.
Old Apr 7, 2017 | 10:20 PM
steve(ill)'s Avatar
steve(ill)
your doing the sleeve CRUSH, then setting the preload, right ????
Old Apr 7, 2017 | 11:32 PM
mrdamron2010's Avatar
mrdamron2010
Yes doing the crush sleeve then setting preload
Old Apr 9, 2017 | 02:59 PM
mrdamron2010
Got it back together can't hear the humming anymore when accelerating but can sill hear a groaning noise when slowing down, seems like i might have an issue with my brakes, u joints, or the pinion bearings, i wasn't able to get a press so i preloaded the pinion, then reinstalled the carrier assembly with new shims etc, installed new fluid meant for limited slips
Old Apr 9, 2017 | 04:51 PM
steve(ill)'s Avatar
steve(ill)
the carrier shims give a little backlash in the gears and about zero clearance endshake ? There may be some gear noise on reused gears that are not exactly set to the original wear pattern ....... check brakes and u- joints.. if not that, some gear noise is acceptable .... why are you still worried about pinion bearing ?
Old Apr 10, 2017 | 06:09 AM
mrdamron2010
Not really the pinion bearing more of it going out on me while driving, not used to driving with gear noise or anything tho, so if its noisey i feel somethings still wrong.... i did research & it seems it's either brakes, u joints, or my pinion bearings... if it lasts till the end of the month ill have the money to replace what needs to be replaced & get new bearings pressed on
aidandj
Nov 25, 2015 02:40 PM
forddriverforlife
Nov 25, 2014 06:32 PM
snakedoc
19
Mar 3, 2014 02:49 PM
splithighlow
1997 - 2003 F150
Jan 24, 2007 08:31 PM
acogoff
May 12, 2002 10:46 AM
