The auto hub is a separate thing from the wheel bearings. The auto hubs are made by Ford and the only aftermarket replacement are manual AFAIK. The wheel bearings should only be replaced with Timken.
How are your ball joints and u-joints? As said I would stick with the Timken unit bearing's too. Best price is Rock-auto and locate a 5% discount for the "how did you hear about us?" box.
Also if the ball joints or seals need replacement I would stick with Spicer as they're the ones who make the axle. With the kit below the only other thing needed is some u-joints.
Ball joints were replaced a couple three years ago. Last time we checked the front end and assessed the hubs (couple months ago) the ball joints were good. They were replaced with Moog greaseable ones. Just got to order the parts and get them done soon.
