Injector or wiring question
Old Apr 3, 2017 | 08:08 AM
Knucks's Avatar
Knucks
Ok I'm close to getting this truck repaired. I just need a little more info. I did the ohms test on my faulty injector and it passed. Then I unplugged all injectors except my faulty one and it's got no clicking going on.. all the other ones do. Am I looking at a bad injector or is it wiring?
Old Apr 3, 2017 | 08:25 AM
Knucks's Avatar
Knucks
Okay I did some more tests. I turned key off and on and tested voltage at wires, 1 to 2 on all injectors wire harness, and number 5 has nothing. All the other ones are showing 8ish volts. 3 to 4 show voltage but nothing at 1 to 2.
Old Apr 3, 2017 | 08:28 AM
87crewdually's Avatar
87crewdually
Plug another injector into that plug on the engine harness AND then plug that bad injector into a known good plug on the engine harness. This will confirm you have a bad injector or wiring.
It's possibly bad injector. But it may be the harness, a plug, or FICM pin.
Old Apr 3, 2017 | 08:40 AM
Knucks's Avatar
Knucks
I think it's wiring tho am I right? I'm getting no voltage at the plug when key on
Old Apr 3, 2017 | 08:42 AM
Knucks's Avatar
Knucks
Plugged in another wire to that injector and it's clicking now, so it's wiring or ficm
Old Apr 3, 2017 | 08:46 AM
87crewdually
There you go. Now check the length of the harness for any rubs. Then pull FICM plug and inspect it. Hopefully it's not the FICM.
Old Apr 3, 2017 | 08:56 AM
87crewdually
Above is the FICM plug for injector 5.
With the injector plugged IN, unplug the FICM and ohm the OPEN pins and then ohm the CLOSE pins. Compare the readings with another injector.
If the reading are the same, it points to the FICM.
If the readings are off, suspect harness side.
Old Apr 3, 2017 | 09:00 AM
Knucks's Avatar
Knucks
No laughing, I found the problem. Not sure if I did this or previous owner. Ill post a picture in a miinute.
Old Apr 3, 2017 | 09:08 AM
Knucks's Avatar
Knucks
Not sure if you guys can see that pin.. bent. Straightened it out and installed. all is good. Not sure how it got bent but at least it's fixed. Thanks again dually. Truck fixed
Old Apr 3, 2017 | 09:17 AM
87crewdually
Nice. That's how it's done!
You can see it. Middle plug 4th pin up on the left row. PIN #21 INJ 5 OPEN COIL POWER
Old Apr 3, 2017 | 09:19 AM
TooManyToys.'s Avatar
TooManyToys.
All injector problems should be this easy.
Good troubleshooting Knucks.
Old Apr 3, 2017 | 11:31 AM
Yama4fitty's Avatar
Yama4fitty
Way to go buddy
That was exactly the route I was hoping you would go with the troubleshooting. Glad some others were able to jump in and help you out to get that beast roaring.
Old Apr 3, 2017 | 11:41 AM
Knucks's Avatar
Knucks
Old Apr 3, 2017 | 12:40 PM
87crewdually
No problem. Glad you found it.
Incase anyone is having trouble seeing it, here it is highlighted a little.
Jay Fletcher
Apr 7, 2013 10:33 AM
00buck75
Apr 2, 2011 01:18 PM
Brutis
Jan 19, 2008 03:43 PM
bigbadwolfe
Mar 11, 2007 05:56 AM
eric777
Sep 8, 2006 12:24 PM
