codes
Old Jun 26, 2007 | 07:05 PM
xlttruck's Avatar
xlttruck
codes
hello yall. i have a 99 f150 5.4. it recently started to skip or buck when applying the throttle. runs fine at idle and when you give it very little gas but when you press the gas just a little more it does it. the auto parts store said there were no codes and the check engine light is not on. i ran the codes thru the odometer and got 2 things i dont know what they mean. one is code-dt AdFA and the other is PE2 12.7. can yall help. thanks, tom
Old Jun 29, 2007 | 05:21 PM
beer boy's Avatar
beer boy
i cant help with those codes, but the drive problem sounds exactly like when one or more of my coils started to crap out. now one or more has totally failed and i am wiating for new ones from summit racing. i had no codes so i though the tranie was on her way out. then the rear end. still no codes but now its definatly a coil (missfire) problem.
Old Jun 29, 2007 | 08:57 PM
2000Ford2000's Avatar
2000Ford2000
See my recent problem post as it sounds like what I just fixed today.
https://www.ford-trucks.com/forums/6...shing-cel.html
Old Jun 30, 2007 | 07:46 AM
projectSHO89's Avatar
projectSHO89
The diagnostic "codes" from the "odometer" cannot give you any useful data from the engine management system.
You have a misfire, just like 2KFORD2K did.
You will either need to press the engine while in the misfire mode to get it to set a CEL and fault code, replace all the coils and plugs, or take it to someone with a scan tool that can read the Mode 6 data and see which cylinder(s) has elevated misfire counts.
Steve
Old Jun 30, 2007 | 03:29 PM
xlttruck's Avatar
xlttruck
i fixed it today yall. the service engine soon light finally came on today, went to oreilly auto parts, where my wife works, put the scanner on it. cylinder #4 misfire, replaced the cop, and problem solved.
Old Jul 1, 2007 | 08:09 AM
projectSHO89
Bingo! Typical failure scenario.
Family discount on auto parts certainly can help!
Steve
Old Jul 1, 2007 | 09:16 AM
2000Ford2000
I've been really impressed with OBD codes since they became available years ago. With those codes and the help on here, I've been able to fix all my CEL's I've had on my 2000.
On the 2000 over the last 3 years, I've replaced the IAC, thermostat, and now a COP, all due to a code and help on here.
When I tell others about the codes, I find lots of them want to borrow my code reader as they also have CEL's on. That reminds me that I need to take my reader to work tomorrow because my boss wants it. I just got it back from a co-worker just last week.
Old Jul 9, 2007 | 06:58 PM
2000Ford2000
Ya, now after fixing one, now #8 is doing the same.
buzter
Modular V10 (6.8l)
May 12, 2015 12:04 PM
EXbowtieguy
Jan 6, 2012 05:55 PM
joebobco
2004 - 2008 F150
Dec 12, 2010 11:44 AM
Deadman2891
Jul 17, 2004 10:39 AM
KeithE524
35
Jun 14, 2004 07:42 AM
