need a 6.0 expert
Old Apr 1, 2017 | 07:57 PM
buzz1964's Avatar
buzz1964
need a 6.0 expert
ok bought a 04 250 6.0..would not run..only code was icp.changed icp no run .put in a couple more still no difference.truck runs with icp unplugged..shuts down immediatly when plugged back in.put in a new factory harness 2 new ecms 2 new ficms same problem .all streams on diagnostics are on line.changed everything on truck.all pressures are streaming fine.have had at least 20 of the best diesel guys around look at it with no clue to problem.if truck is cranked long enough it will try to start with icp plugged in but sounds out of time..now for the real kicker we put in a 05 ecm truck runs fine with icp plugged in ,but you lose all dash funtions..the guy before me had this truck worked on for 5 yrs. and not even a ford tech could figure it out... so now im trying...so whos the real expert on here..thought i would give this site a try and see..thanks buzz
Old Apr 1, 2017 | 08:42 PM
VictorwithaC's Avatar
VictorwithaC
Are you using an ICP from Ford? Not aftermarket? Then to add to it are all the other sensors from the pcm Ford? Have you checked the ground? Or reference voltage?
Old Apr 1, 2017 | 10:03 PM
buzz1964's Avatar
buzz1964
all parts are ford..redid the entire grounding system and added to it..a senior tech from ford looked at this truck and still doesnt understand the problem
Old Apr 1, 2017 | 10:08 PM
FiznUKa's Avatar
FiznUKa
Ever install an 03-04 ECM? Disregard reread your post
DarkStarMedia's Avatar
DarkStarMedia
Get us some live data. Also does it crank smoothly?
Richard
Old Apr 1, 2017 | 10:19 PM
FiznUKa's Avatar
FiznUKa
Is the ICP on the PS valve cover or behind the turbo. If on the valve cover has the oil rail been checked for a blockage.
Old Apr 1, 2017 | 11:16 PM
Yama4fitty's Avatar
Yama4fitty
Just FYI guys, the OP has this posted in the Super D forum too.
Old Apr 1, 2017 | 11:18 PM
VictorwithaC
is yours an early style or late? I don't think it matters but there are two different sensors. Maybe your pcm doesn't like the late style sensor if your early style and have the wrong one in.
Old Apr 2, 2017 | 12:01 AM
buzz1964's Avatar
buzz1964
ps valve cover early 04 12 of 03 rail pressure is very goodphysicly checked and good on the stream
Old Apr 2, 2017 | 12:02 AM
buzz1964's Avatar
buzz1964
and yes i have this posted on a couple of the forums just learning my way around here
Old Apr 2, 2017 | 12:28 AM
FiznUKa's Avatar
FiznUKa
Try unplugging your fan clutch wires.
Old Apr 2, 2017 | 08:46 AM
VictorwithaC
Maybe also try unplugging the egr valve. Make sure all the sensors on that line are oem I can't stress that enough.
buzz1964
Apr 2, 2017 11:23 AM
father6
Jan 12, 2015 08:57 PM
altonlee
Nov 5, 2012 07:06 PM
cabinman
Aug 31, 2009 07:23 PM
spin498
Aug 29, 2007 04:32 PM
