Georgia Chapter Join Chapter, Leader: OPEN SPONSORED BY:
April 2017 chat
Old Apr 6, 2017 | 11:44 AM
  #31
hturner12's Avatar
hturner12
I have to check it out
Old Apr 7, 2017 | 01:06 PM
  #32
ChiefM's Avatar
ChiefM
TGIF !!
3 more weeks till beach weekend!
We removed the 16 foot blade we just put on a D8 to test it out this morning, thank goodness that tractor is done and shipping out. Doing new machine in processing on, a lot less work!!
Old Apr 7, 2017 | 01:09 PM
  #33
Airborne-F250's Avatar
Airborne-F250
yay Friday!!!
ill be finishing the shed I started last weekend
then putting the hurt on big red to get the bed patched and rhinolined so I can get the topper on it and off brownie!
Old Apr 7, 2017 | 05:32 PM
  #34
hturner12's Avatar
hturner12
That a big blade
Hopefully I got the rear tank fixed. The return line fitting came off in my hand. Pressure tested it founder leaks around the sending unit gasket. Replaced it still had a few bubbles so I sealed around it with rtv. Cut a piece of rubber hose and two clamps for the return line. At least it will be easy to get to now. Cut holes in the bed and put a plate over over the holes.
spent all day today at the land spreading asphalt millings
Old Apr 8, 2017 | 04:23 AM
  #35
ChiefM's Avatar
ChiefM
That D8 was a pipeline build and we also added a 20 ton winch to the back. It's one big mother. I guess the mom in-law is moving into her house today. I have to move her bedroom stuff to her house, do some backyard clean up and then measure out for a privacy fence she wants put up.
I was able to wet vac out the water in the basement and mow the grass yesterday so I am a little ahead on weekend chores.
Old Apr 8, 2017 | 05:47 AM
  #36
hturner12's Avatar
hturner12
Just think it is not the biggest. Did you rem8nd here your not that young anymore and you don't like digging post holes
Old Apr 8, 2017 | 06:32 AM
  #37
ChiefM's Avatar
ChiefM
Originally Posted by hturner12
Your not that young anymore and you don't like digging post holes
I remember
They have a 2 hp post hole digger for 200 bucks at Harbor Freight. Might be cheaper to buy one than renting one.
Old Apr 8, 2017 | 06:52 AM
  #38
hturner12's Avatar
hturner12
But how much use would get afterwards
Old Apr 8, 2017 | 01:48 PM
  #39
yankbs 66f100's Avatar
yankbs 66f100
Hugh, you can rent it from Chief when it comes time for your fence. Chief will busy putting up new fences to separate the pastures as the herd will continue to grow.
Old Apr 8, 2017 | 07:53 PM
  #40
hturner12's Avatar
hturner12
Bob
I pass on the 2hp post hOle digger. If I can not get to with the tractor and the 3 point porthole digger I put a tpost in spot. To fence all 8.65 acres will be about 5000 ft
Old Apr 8, 2017 | 08:36 PM
  #41
ChiefM's Avatar
ChiefM
Another long day has finally come to an end. I ended up just digging the holes with my manual post hole digger. Only one had some roots but my back and shoulders are sore. All in all it wasn't too bad considering it could have been rocky like my yard. Only a few little things to wrap up tomorrow morning and I should be done for a while.
Old Apr 8, 2017 | 10:15 PM
  #42
Airborne-F250
Ya i finished my shed today!
Now to more fun things like big red
Old Apr 9, 2017 | 03:48 PM
  #43
ChiefM's Avatar
ChiefM
Mom is moved in and her privacy fence is up!!! Now maybe I can get caught up on stuff around here that has been put on the back burner trying to finisher her up.
Old Apr 9, 2017 | 03:51 PM
  #44
hturner12's Avatar
hturner12
At least you can go back to work and hope for easy stuff so you can rest
Old Apr 9, 2017 | 07:11 PM
  #45
yankbs 66f100
Don't you mean go back to work to get some rest. Cut, and trimmed the MOL's yard this morning, then mine this evening. At least I get back on the regular weekend schedule after three Saturdays in a row. Get back to work on the footings for the new carport for the truck next weekend.
