Resurfacing head necessary after overheating?
Old Mar 30, 2017 | 10:28 PM
z31freakify's Avatar
z31freakify
As the tittle implies I know these cast Iron heads are hard to warp but is it necessary? Can I just follow the removal torque sequence and avoid resurfacing the heads that's if they pass the straight edge ruler? Why am I asking this? The Mules heads are coming of soon and if I like what I see I'll just do head gaskets worst case scenario I'm ripping the engine out if the cylinder walls are damage. I'm doing a really and I mean a really budget head gasket job. I'm in head gaskets and valve stem seals $50 THANK YOU commercial discount.
Old Mar 31, 2017 | 07:50 AM
fordman67's Avatar
fordman67
If you have a machinist straight edge and its within a couple thousandths it might be OK. I'd hate to do all that work and have that come back to bite me.considering your status tho. .... Maybe let it roll. When you have it apart you will know more. Get er dun!
Old Mar 31, 2017 | 02:25 PM
lee00's Avatar
lee00
What he said there....
they are easier to find than you think...ask any of your engineer friends and you have to check it multiple ways....
Old Mar 31, 2017 | 02:38 PM
knottyrope's Avatar
knottyrope
ever use a mirror? I have done this in the past on suspect blocks
put non shiny side on the surface to test and press all four corners down but not enough to break the glass and press in other areas that are not recessed
look at graph paper in reflection and distorted areas show the warp
Old Mar 31, 2017 | 04:49 PM
z31freakify
I know how to check for warpage, but most of my head job experience dealt with aluminum heads and or aluminum blocks, but not with cast Iron heads, according to my machinist cast iron heads are nearly impossible to warp the head gasket give ways first.
Old Mar 31, 2017 | 05:00 PM
fordman67's Avatar
fordman67
just how hot did it get?!?!
Old Mar 31, 2017 | 05:12 PM
strokin'_tatsch's Avatar
strokin'_tatsch
As far as warpage goes, they are much harder to warp than aluminum, but they can still warp a tiny bit just from taking them off. The torque sequence usually flattens them back out though. I would be checking them very closely with a straight edge and see how bad it is. Then figure out what a tolerable amount is.
When you clean the block and head surface, dont use a puck or anything on it. It's going to take forever, but use razor blades to clean it until you cant get anything else off of it. It usually takes me hours to get one side of the block 100% clean.
Old Mar 31, 2017 | 07:30 PM
z31freakify
Not much, a quick glance showed me the idiot gauge was @3/4 steadily going to red and there was another light indicating "HOT" or something like that just cant remember.
Old Apr 1, 2017 | 07:02 AM
fordman67's Avatar
fordman67
I would imagine that was the over temp lamp. I can't remember what temp it actuates but iirc its pretty darn hot. This all is just conjecture until its apart. I am with Travis I have gotten away from wizzer wheels to remove gasket material for the most part. Only nonprecise stuff gets that treatment. I feel like a nice razor blade does well and no chance of doing harm to the surface.
Old Apr 1, 2017 | 09:48 AM
oldbird1965's Avatar
oldbird1965
I had that 'hot' light come on and the gauge only showed a little to the right of center. I just ignored it, put in a terminator 180° and never saw the light again.
Old Apr 3, 2017 | 08:33 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Hey Adam, I have a couple heads you could buy.... attached to the rest of an engine hahaha check the posted to classified thread
Old Apr 3, 2017 | 11:22 AM
z31freakify
I got spares that are going to my other engine but stupid me forgot to bathe them in oil and on the finish resurfaced head rust appear and bad, it's going to need resurfacing again aghh.
cts1954
17
Jun 27, 2009 01:32 PM
triggr31
Jan 2, 2009 08:45 PM
40LUTZAG
1997 - 2003 F150
Sep 28, 2006 12:57 PM
sdloe
Apr 12, 2004 09:37 PM
knucklehead11
Bronco II
41
Jul 30, 2003 07:18 PM
