Removing engine fan.
Old Mar 28, 2017 | 07:16 PM
ugh3012's Avatar
ugh3012
What is the best way to remove engine fan from 2001 F250 with 5.4 V8? I need the fan out of way to give me better access to swing hammer on AC clutch. Can I remove the bolts on the fan clutch to remove the plastic fan?
Old Apr 1, 2017 | 07:16 PM
enriched&beyound's Avatar
enriched&beyound
Pretty sure its like 36mm nut on the fan and it should be right hand threads.
I usually have good luck with the belt still on and can get it to pop loose with the aid of a good thump of a dead blow hammer on a wrench. Once loose it should unthread by hand the rest of the way. If that isn't working you may need to find a pneumatic style wrench to get it to break loose.
Some parts stores have fan clutch tools you can rent.
Old Apr 2, 2017 | 10:26 AM
ugh3012's Avatar
ugh3012
Thanks. That will help.
tdpower
19
Dec 4, 2010 12:46 PM
Buford
1997 - 2003 F150
Jun 1, 2010 05:37 PM
BadAssFord
1997 - 2003 F150
Dec 27, 2007 12:12 PM
fishnstash
1997 - 2003 F150
Jan 10, 2006 06:36 PM
RomerB2
Bronco II
15
May 12, 2005 12:59 PM
