Fan removal?
Old Mar 10, 2010 | 11:53 AM
tdpower's Avatar
tdpower
Fan removal?
I need to replace my fan due to damage on the old one. Can I do this without removing the fan clutch. It looks to me I just take off the 4 bolts on the back and might have to remove the shroud. I tried the search but only found the fan clutch removal. Thanks
Old Mar 10, 2010 | 11:56 AM
mongo75's Avatar
mongo75
No, you gotta put the fan removal tool on the nut behind the fan, and then spin it off. I wish it was that easy as pulling the four bolts (unless I've been doing it the hard way all along LOL)
Old Mar 10, 2010 | 12:27 PM
PaysonPSD's Avatar
PaysonPSD
If you do have to remove the fan and clutch here is a video of water pump R&R. The first part shows how to remove the fan and cutch assembly and tools needed. LINK
Old Mar 10, 2010 | 12:47 PM
tdpower's Avatar
tdpower
Ok, thanks guys. I got the part on order so will be doing it next week. I still don't quite understand why you can't remove the four bolts. Don't those hold the fan on to the clutch?
Old Mar 10, 2010 | 01:01 PM
clem1226's Avatar
clem1226
the fan mounts to the back of the clutch so the clutch had to slide through the fan before you install the clutch on the water pump.
Order of removal for me:
1: drain and remove coolant tank, you could try clamping off the large hose running from the tank to the radiator but you may have to drain the radiator enough to get the water level below the opening in the outlet of that hose.
2: disconnect fan clutch from water pump or just break it loose so it's only held on by a few threads
3: remove fan shroud, clutch and fan together.
re install n reverse order
Old Mar 10, 2010 | 01:26 PM
quick_4.6's Avatar
quick_4.6
Spin it on/off with an air hammer. It's not that tight.
Old Mar 10, 2010 | 01:45 PM
clem1226's Avatar
clem1226
huh? yes an air hammer would get it off in a pinch but a fan clutch removal tool can be borrowed or made pretty easy. Sometimes even a strap wrench can get the job done.
I am not too sure I would want to hit my water pump and fan clutch with an air hammer , or any kind of hammer for that matter. unless I had exhausted all other solutions and it was seized.
Old Mar 10, 2010 | 02:32 PM
quick_4.6's Avatar
quick_4.6
To each their own but the fan only needs a tap to come loose. Just trying to save someone the aggrivation of tracking a special tool down.
BTW - this is the way i was shown buy a certified navistar diesel tech.
Old Mar 10, 2010 | 02:37 PM
tdpower's Avatar
tdpower
re
Thanks for the tip. I might do it that way. I read in another thread a couple of guys recommended doing it the same way.
Old Mar 10, 2010 | 07:06 PM
mongo75's Avatar
mongo75
I had to change my water pump in the driveway, so luckily I had a piece of 1/8"x4" steel laying around, I cut it out to make a wrench for the nut on there fan. The belt held it pretty good to loosen it. I just disconnect the screws holding the coolant container and swing it over in between the battery and a/c compressor and then loosen up the shroud, and you can either drop it down, but it's easier to pull it up and out. Once you do it the second time only takes like 10 minutes. I can now pull a turbo in about 20 minutes LOL- it gets easier with practice
Old Mar 10, 2010 | 08:02 PM
tdpower's Avatar
tdpower
Thanks for all the advice guys! I was hoping not to drain the reservoir. It seems like a pretty easy job once you get the fan clutch off.
Old Mar 10, 2010 | 08:35 PM
clem1226's Avatar
clem1226
good to know, the more I think about it the better sense it makes. Thanks for posting!!
Old Mar 11, 2010 | 01:35 AM
mongo75's Avatar
mongo75
Someone showed me one way to take the bolt out of the crankshaft snout- put a long azz breaker bar on it, and bump the starter a hair...
Old Mar 11, 2010 | 03:09 PM
clem1226's Avatar
clem1226
I've done that when there was no room for leverage or I cant get an impact in there.
Works best with a remote start momentary switch hooked directly to the starter solenoid so you can keep an eye on it.
Old Dec 4, 2010 | 10:22 AM
97powerstroke250's Avatar
97powerstroke250
Is and should are two different things i tried to get mine off with air hammer no luck.
