How to remove this antenna
Old Mar 30, 2017 | 09:45 AM
HoustonDave's Avatar
HoustonDave
77&79 - small correction - if you remove that Phillips head screw which holds the split-ball antenna mast to the base, you will find a second Phillips head which holds the base to the under-fender retainer. No need to turn the base, just remove that screw.
Old Mar 30, 2017 | 10:43 AM
79 F-150 Stone's Avatar
79 F-150 Stone
Ha ha, that screw head was stolen long ago by a Mr. Rust, but no biggie, vice grips did the trick.
Old Mar 30, 2017 | 12:44 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yes you are correct HD thanks for covering that, I was starting to strip the ball mast phillips screw, so I just put upward pressure on it and gave it a turn and got it to loosen up that way.
No fear in scratching the paint........ that applied with a roller.
Race Chapman
Dec 11, 2017 03:31 PM
SolusUmbra
1983 - 2012 Ranger & B-Series
Oct 17, 2014 08:17 AM
FitchBanjos
Apr 29, 2008 04:44 PM
Bill W
Jan 20, 2008 11:16 AM
Drusplanet
1978 - 1996 Big Bronco
Mar 17, 2004 04:09 AM
