7.3 Codes ... WHAT DO THEY MEAN?
Old Mar 28, 2017 | 09:26 AM
Gear619's Avatar
Gear619
Ok so I have a 02 f350 7.3 6 speed with 85,000 miles on it .... the ABS light has been on since i bought it a year and a half ago so i decide to scan it and basically scan the whole truck for fun ... So had a few codes come up and i was wondering what each one meant and what may be wrong and how to fix it.
P0541 - Intake Air Heater a Circuit Low ... Id assume this code popped up due to me doing an Intake heater delete plug.
These 2 have my most concern:
P0269 - Cylinder 3 Contribution/Balance Fault
P0284 - Cylinder 8 Contribution/Balance Fault
What do these mean !?!?!? What is wrong with my cylinder 3 and 8?
Then I had these 3:
P1536 - Parking Break Switch Circuit ... My parking break is very weak, how do i fix this issue?
C1145 and C1230 - Front and Rear Speed Sensor input ... Id assumme this may be my issue for the ABS light. How do I fix it?
Any information especially on the 3 and 8 cylinder faults would be MUCH appreciated .... THANKS GUYS !!!
Old Mar 28, 2017 | 10:21 AM
Rikster-7700's Avatar
Rikster-7700
Now you have documented the existing codes you will probably want to reset the and see what comes back.
As to the AIH code, you are correct, if it has been deleted, and there has been no resistor placed in there to "fool" the system then it will appear.
The contribution fails are more than likely from running the grey CPS, 3 & 8 are usually the ones that fail on this CPS.
As to the speed sensors, they could be going bad, but if I understand correctly there should be other issues surfacing if they are bad. It will be interesting to see what codes reappear, we will have a better idea where to start looking.
The ABS light could be down to a bad speed sensor, but if your truck is like mine (also an 02) then there are also ABS sensors on the front hubs, you may want to make sure these are plugged in properly because these will throw the light on too.....
Old Mar 28, 2017 | 10:27 AM
Walleye Hunter's Avatar
Walleye Hunter
What Rickster said+...I believe that we all have weak parking brakes, I never seen one as weak as mine before.
Old Mar 28, 2017 | 11:41 AM
Gear619's Avatar
Gear619
..... I hear that the dark blue CPS is the best one for these motors now ? Is this true and what brand are the dark blue ones and where can I get one? Part #?
Old Mar 28, 2017 | 01:11 PM
Rikster-7700
They are the latest ones that people like to use. With sensors on these truck ALWAYS go with OEM, so motorcraft / international is the way to go (the dark blue ones are OEM btw).
Take a look at Riff Raff Diesel, they have exactly what you need and are an excellent vendor to work with. Just try and spend as little time as possible in there though, otherwise your basket will be full and you will be wondering how on earth it happened (and which kid you are going to sell to pay for it!).
Old Mar 29, 2017 | 05:48 AM
Gear619's Avatar
Gear619
Thanks guys .... You where a lot of help, I appreciate it !
Old Mar 29, 2017 | 07:55 AM
Tugly's Avatar
Tugly
Ignore these:
About 20% of the trucks have one or both of these faults, with no real issues.
jmo1112
Nov 24, 2017 05:06 PM
SD33Tfan
Jan 31, 2015 12:35 PM
softie
19
Jul 28, 2010 12:10 PM
mudvayne0882
1997 - 2003 F150
Aug 23, 2007 06:20 PM
dyarumian
1978 - 1996 Big Bronco
Feb 17, 2004 09:09 PM
