Sponsored by: Auxito
ABS Light
Old Aug 21, 2007 | 07:47 PM
mudvayne0882's Avatar
mudvayne0882
ABS Light
ABS light is on, anyone know what the most common problem is, or where I should start.
Thanks
Old Aug 22, 2007 | 08:09 AM
sandrat's Avatar
sandrat
Going to need to have codes pulled before you can do much else. Could be anything from a relay not powering up the system to a speed sensor or even an HCU (pump and valve assembly roughly) or an ECU (module). But you can't look at anything until you know what code you have. For some reason I'm thinking Autozone CAN'T pull abs codes (anyone out there know for sure? correct me if I'm wrong), so you'll either have to find a scanner you can borrow, buy one (make sure it will work!) or stop at a shop and just have them pull codes if you're confident you can diag it once you know where to start.
Old Aug 22, 2007 | 08:31 AM
xtrford's Avatar
xtrford
Requires a special scanner to pull the codes.....most likely the culprit is the rear speed sensor located at the top of the diff.
Old Aug 22, 2007 | 09:15 AM
mudvayne0882
Thanks
Thanks for the info will be taking it to a buddy with a scanner. Thanks for your help.
Old Aug 22, 2007 | 03:37 PM
Mark00F150's Avatar
Mark00F150
I found my problem without pulling the codes, found the wires had come loose off the main module next to the steering column.
Old Aug 23, 2007 | 06:20 PM
mudvayne0882
Thanks
Got the truck scanned, and lone behold is was the rear speed sensor. Thanks for all your help!!!
