89' fuel problem
Old Mar 26, 2017 | 06:23 PM
saltbranch's Avatar
saltbranch
89' fuel problem
I have searched and I guess I am not searching correct term. I have 89' F250, 351. I bought the truck with fuel problem. The selector valve is new from when I purchased. Truck ran good for a few days then, stalled out-like ran out of gas. Took to my local mechanic and it was determined the the front pump went out. Replaced that and it seem to run good. Drove it for a day, problem came back. Only this time, I could let truck sit for a few minutes ,fire it up run about a 1/4 mile then die. Let truck set for 2-3 minutes and repeat. I removed the gas cap off the front tank as thats the one I was running on, thinking vacuum? no difference Any suggestions? guidance to other posts dealing with this?
Old Mar 26, 2017 | 07:30 PM
88n94's Avatar
88n94
Have you changed the fuel filter? The fuel filter should be easy to change on that truck. I would try that first.
Old Mar 26, 2017 | 08:25 PM
saltbranch's Avatar
saltbranch
I cant say for sure TBH. I will try that next. I will update....the woas of buying some elses project!
Old Mar 27, 2017 | 07:37 PM
saltbranch's Avatar
saltbranch
Filters were changed when the pump was changed by my local mechanic. It seems the problem starts once the truck is warmed up. Any ideas?
Brad_81Ford
Jan 15, 2012 10:21 AM
williamgrogan
May 31, 2011 12:41 PM
bad luck
Aug 17, 2007 11:53 PM
DaFarmer
Nov 18, 2003 05:13 PM
