fuel problem
Old Aug 13, 2007 | 09:34 AM
bad luck's Avatar
bad luck
fuel problem
I have an 1986 F-150 that has started to act like it is running out of gas. It will start up and ican drive it for several miles and then it will start sputtering and dieing out and if i play with the gas sometimes it comes back. most times it shuts off and I have to leave it sit for awhile before it will start up. Any ideas? I did put on new gas cap and changed the fuel filter.
Old Aug 13, 2007 | 01:35 PM
Franklin2's Avatar
Franklin2
Leave the gas cap off and see if it quits doing it. Your emissions hoses to the tanks may clogged.
Old Aug 13, 2007 | 03:48 PM
wedebrook's Avatar
wedebrook
if the fuel pump is leaking, its probably bad.
Old Aug 17, 2007 | 11:53 PM
southern//magic's Avatar
southern//magic
the diaphram in ur fuel pump is goeing out or ur filter is clogged i gaurantee it man i usedd to have the same problem all the time
