headers
Old Mar 25, 2017 | 08:10 PM
Rusty78150's Avatar
Rusty78150
headers
I have a 1978 f150 4x4 frankenstein. It has doors and front clip from an f250 and the vin decodes 2wd. Vin also decodes 351m. It has a 351w. I need headers. Has anyone else ran across this problem? Every part number I find lists only the 351m. Any help would be appreciated.
Old Mar 26, 2017 | 12:01 AM
HIO Silver's Avatar
HIO Silver
Apparently all too often.
You do realize the 351W wasn't offered in this generation truck, right?
Try shorty 302 Mustang headers or shorty early/late Bronco headers.
Old Mar 26, 2017 | 09:56 PM
Rusty78150's Avatar
Rusty78150
Im well aware of this. Just curious if anyone else has done this. Im sure I dont have the only 73-79 f150 with a windsor. Any help would be appreciated. would headers for an 80 up fit? Thanks
Old Mar 26, 2017 | 10:02 PM
HIO Silver's Avatar
HIO Silver
Your awareness of the issue could not be deduced from your original post.
"Late Broncos" means those offered with a 351W.
Good luck.
Old Mar 26, 2017 | 10:21 PM
buckin69bronco's Avatar
buckin69bronco
It's the motor and the frame that matter... Is yours a 2x4 frame with a front axle or is yours a 4x4 frame?
302 headers for an early bronco might fit and so might 2x4 headers for a f100 with a 302. You may need to do some customizing though
Old Mar 27, 2017 | 09:38 AM
good to doo's Avatar
good to doo
Long tube headers for a 302 won,t work on a windsor. The Windsor has a taller deck height which makes the headers angle in too far and interfere with starter clearance. 90,s mustang shortys may work?
Old Mar 27, 2017 | 10:40 PM
Rusty78150's Avatar
Rusty78150
I believe thus cab was sat on a 4x4 frame.
Old Mar 28, 2017 | 09:38 AM
good to doo
It doesn,t matter what frame is involved. Long tube Windsor headers won,t work on a 302. My friend has an 81 f2504x4, that he put a windsor into, he has long tubes on it, hedman I think. So maybe that is an option.
Old Mar 28, 2017 | 09:44 AM
HIO Silver's Avatar
HIO Silver
I'm probably splitting hairs but both the 302 and 351W are Windsor engine designs.
The term "Windsor" in this thread is casually being used to differentiate the 351W from the 302 but for newer enthusiasts potentially reading this thread that could be somewhat misleading.
Old Mar 28, 2017 | 09:55 AM
good to doo
Windsors have a taller deck height. Some parts are interchangeable with the 302.
Old Mar 28, 2017 | 10:12 AM
gittinwidit's Avatar
gittinwidit
There's no long tube headers available although if you have a 110 welder and some tube, you can make a set. The issues is the deck height vs the coil towers vs the starter vs the tranny linkage vs everything else in the way. They would be very kinky before they were done but still possible for you CAN see a daylight trail through there. But they would need to go way up before coming back down. I'd hate to change spark plugs after that...
I've heard either a 80-86 passenger side or it may be the driver's side will fit with some slight modifications but that's it to get you started.
1979fordjunior
Sep 4, 2010 09:58 AM
71fordkid
15
Jan 3, 2007 03:41 PM
mbricke0
Dec 6, 2003 10:33 AM
taz500000
May 10, 2002 11:47 AM
bpowell
May 1, 2000 06:27 AM
