79 F250 351w headers?
Old Dec 4, 2003 | 08:42 PM
mbricke0's Avatar
mbricke0
I got a 1979 F250 4X4 with a 351W in it... not a 351M. im looking for some headers but they don't make em' for that specific swap. anyone know if the 1980-1987 351W headers offered by hedman will work? any suggestions and input is greatly appreciated. matt.
Old Dec 5, 2003 | 11:53 AM
loudfords's Avatar
loudfords
The later headers can work with custom exhaust pipes, so will Mustang headers. 302 headers will fit a 351 with 2wd but I don't think so for 4x4.
Old Dec 5, 2003 | 02:56 PM
Pentekno2's Avatar
Pentekno2
With this you will want to be very careful which you choose, you would be best off trying to find some shorty headers or block hugger headers. Even in that case, you can never be too sure what the clearances will be and whatnot.
You don't want to spend 120 dollars on a set of headers just to find out that they exit directly over the frame rail with less than an inch to spare, do you?
Try a search through the forums, or even try looking through the galleries to see if there are any other trucks running this same engine as you are (351w) and if they are running headers on it, simply ask them what they used and any difficulties they may have had.
-Pentekno2
Old Dec 5, 2003 | 03:28 PM
loudfords's Avatar
loudfords
Like mine with a 351w and headers!
Old Dec 5, 2003 | 11:51 PM
Pentekno2's Avatar
Pentekno2
Also keep in mind That that 2x4 and 4x4 frame placement may be different, there could also in certain cases be problems with the transmission (auto vs. manual), thats why sometimes when your looking for headers you see then with an * or a small reference number next to it, and you read that reference number and it may give you a message like: "auto trans. only"
-Pentekno2
Old Dec 6, 2003 | 10:33 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
I needed a set for my drag car and i went to one of the national parts stores they said i could try them but dont scratch them so they order the ones i thought would work . They did not work i took them back got my money back and a better understanding of what i needed. Hope this helps.
KSun90
Mar 3, 2021 12:42 PM
BossFan
17
Mar 6, 2019 08:04 PM
BossFan
Jan 6, 2019 07:14 PM
Dekoda Dale
18
Aug 16, 2015 10:30 AM
hdgapeach
May 5, 2014 02:51 PM
