Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
73 F750 Sputtering?
Old Mar 24, 2017 | 11:11 PM
Cancotree's Avatar
Cancotree
73 F750 Sputtering?
Hi all. Got an issue with my dump truck. Was hoping for some help. First of all it has a 391 FT with a 5 speed When I shift into 5th gear it starts spitting and sputtering and hesitating real bad. I can pull the choke out all the way and it levels out. Once it accelerates a little bit I push the choke back in and it runs smooth every time. Only does this when I first shift into 5th gear. All other gears are smooth and very strong. Can't figure it out. I put a brand new carb on it. New plugs, wires, cap and rotor. Used dry gas. Running 93 in it. Nothing helps. It was running great then one day started this problem. Any help would be great! Thank you
Old Mar 26, 2017 | 11:19 PM
85e150's Avatar
85e150
WAG alert: Power valve in carb is wrong size or damaged. Older Holley carbs are vulnerable to power valve damage if the engine backfires. Did you have a backfire issue after which it started running like this?
You may also be running out of fuel. Float level too low, or lack of fuel pressure could starve you after a run through the gears and then the initial load in 5th.
Vacuum leak could do it too.
Old Mar 27, 2017 | 06:49 AM
Cancotree's Avatar
Cancotree
Thank you for the reply. First thing I did was replace the carb with a brand new because I had heard of the power valve issues. No vacuum leaks that I could find. I'll look into fuel pressure. Never thought of that. I had assumed that if it could get to 50 the fuel pump was good. But you know what they say about assuming lol
Old Mar 27, 2017 | 05:56 PM
85e150's Avatar
85e150
New carb or not, it may need a bigger valve and/or float level might not be right for your application. Good luck!
Old Mar 27, 2017 | 06:01 PM
Cancotree's Avatar
Cancotree
It had a 4160 on it before this started and it ran great. So I replaced it with a 4160. I'll have the float levels checked. Thank you!
Old Apr 15, 2017 | 10:44 AM
Cancotree's Avatar
Cancotree
Frustrated
Im at a complete loss and frustrated as hell. I had to carb adjusted. Replaced fuel pump and filter. Pump has great pressure. Used dry gas. Replaced plugs wires and cap AGAIN. Put a new air filter on it. Still the same. No change whatsoever. It will run great for a few miles then spit and sputter when you give it gas. Gotta drop all the way down to third to have any power. Then all of a sudden it'll be fine again. I just dont get it. I could really use some help. Thanks
Old Apr 15, 2017 | 10:46 AM
Cancotree's Avatar
Cancotree
Add
Also no vacuum leaks that I can find. It sits there and idles perfectly.
Old Apr 16, 2017 | 03:19 PM
Cancotree's Avatar
Cancotree
Woohoo!
Finally! Problem is fixed. Oil breather/separator was bad. Had a hole in it. Was letting oil get into the carb. Replaced the breather and plugs and she runs like a top!!
Erik Jaeke
Oct 27, 2015 01:06 AM
Coastal68
33
Oct 1, 2015 12:27 PM
mikeymadness
Jan 4, 2011 06:17 PM
Killroy
Jul 19, 2010 06:04 PM
x_FordMan_x
Mar 15, 2002 05:14 PM
