1978 F150 poor performance
Old Oct 26, 2015 | 09:40 AM
Erik Jaeke's Avatar
Erik Jaeke
My old truck just decided yesterday to start driving like crap! It stalls (mostly at stoplights, but also when simply driving down the road), and it cuts out when the accelerator is pushed. I'm assuming plugs, wires, distributor issue but the plugs and wires are brand new. It also has a new fuel filter. Fuel pump perhaps?
The auto choke on the carb is busted, and I've tried idling it higher but that only helps when in Park. When in gear, it runs very low and stalls. But while it is actually RUNNING, the motor sounds great and does not skip.
400ci, automatic, 4wd supercab, 1978.
I'm going to check these issues out when I get off work, but I'm wondering if those of you smarter than I have any bright ideas. Anything you have is appreciated!
Old Oct 26, 2015 | 10:16 AM
wyrm73's Avatar
wyrm73
I think you are on the right track with fuel issues, but Carb issues is what comes to mind first to me. Float going bad or jet picked up a piece of crud and is partly blocked? Have you checked the vacuum line to the distributor? No advance might explain it too and easier than tearing into the carb.
Old Oct 26, 2015 | 10:29 AM
CelticOne's Avatar
CelticOne
Regular User
Check the accelerator pump on the carb. If the diaphragm is leaking that could cause at least some of the issues you are experiencing such as cutting out when the accelerator is pushed.
Erik Jaeke's Avatar
Erik Jaeke
Thanks for the reply. I have checked that vacuum line and it has plenty of suction. I think I may need to get into the carb... UGH.
Any thoughts on the ease of installing a new carb? Since the choke is already busted, the float is basically non-functional, etc... would it be better to just replace it?
Old Oct 26, 2015 | 10:30 AM
Erik Jaeke's Avatar
Erik Jaeke
Okay thanks! Can you explain where the accelerator pump is at? I know next-to-nothing about carbs.
Old Oct 26, 2015 | 10:33 AM
wyrm73's Avatar
wyrm73
I'm a bad person to ask. I HATE working on carbs. Despite my obvious bias, I think the performance gain might be worth changing it for an aftermarket if you are still running factory. Far cheaper to rebuild though.
Last edited by wyrm73; Oct 26, 2015 at 10:35 AM. Reason: Missed a few words in there... must type slower...
Old Oct 26, 2015 | 10:55 AM
CelticOne's Avatar
CelticOne
Regular User
I have a stock Motorcraft 2150. The accel pump is #2 in this image: http://grantorinosport.org/BubbaF250...accpump_01.jpg
Front driver's side of carb. Four bolts to remove - be careful the spring doesn't get away when you remove the cover.
However, it sounds like you might be better off with a remanufactured carb - just replace the whole thing. But I am by no means an expert - listen to what the other guys here tell you.
Good luck.
Old Oct 26, 2015 | 11:01 AM
Erik Jaeke's Avatar
Erik Jaeke
Perfect, yes I have the same carb. I will check it out. I will consider a remanu carb, but the darn truck was running great until yesterday! thanks!
Also - I've followed threads about vacuum diagrams (the lack thereof) and I'm also wondering if I have improperly connected vacuum hoses. I will try to get more edu-ma-cated
Old Oct 27, 2015 | 01:06 AM
burnthelight88's Avatar
burnthelight88
If there was a big temperature change yesterday, which it is that time of year again, then your carb probably could use some tuning. But after reading some more of your problems, the other guys are right, except that I suggest rebuilding the 2150. There's no reason to buy a new one and if you've got a stock engine I don't see the benefit of "upgrading" to something that will require more parts and cost exponentially more money with little to no benefit. I just completed my first rebuild with little knowledge and its fairly easy.
I ordered the kit and a new brass float from Welcome to Mike's Carburetor Parts - Your Number 1 Carburetor Parts Store aka Mike's Carburetor. It came recommended from guys on here after some searching. It cost me about $70 after the new float and shipping, plus there are multiple 2150 kits and of course the one I needed was the most expensive. The first thing you'll need though is the carb's part# which can be really tough to find.
North42g
Aug 20, 2011 07:22 PM
shiftonthefly1
Aug 9, 2010 11:11 PM
8ITCOOL
13
Jun 3, 2004 09:43 AM
83F-250OWNER
16
Mar 9, 2003 03:45 AM
jessbass
Dec 19, 2000 06:24 AM
