Nitrious?
Old Mar 23, 2017 | 08:53 PM
yohon's Avatar
yohon
Nitrious?
Hello everyone. I have a question that I think I know the awnser to but would like some sager advice. So I have a 390 that Im building up for a daily driver. (1973 f250) im running a mostly stock lower end. Stock rods and crank but flat top forged pistons. Planned on 9.5 to 1 compression raito. Upper end is again mostly stock cast iron. Ill have 68 mid riser heads with 428 cj valves installed. With a cast iron 4b intake. ( really debating on buying a nice eldabrock intake But i have the drip trays with the oil returns down the intake and was told they would not work with aftermarket) new luniti cam ( can post specs if it helps) and im planing on one of them fancy msd boxes. All topped off with a 770 street avenger holley. Real question to all of this can my stock rods handle a bit of nitrious. Id proably only run a 75 or 100 shot. But im not sure what all nos will really do to a motor in the long run. Thanks everyone in advance
Old Mar 24, 2017 | 09:20 AM
MIKES 68 F100's Avatar
MIKES 68 F100
spend your $$ on an aluminum Intake /heads and Headers etc NOS while FUN will shorten the life of your engine .
Old Mar 24, 2017 | 09:39 AM
yohon's Avatar
yohon
Thats bout what i figured thank you sir
Old Mar 24, 2017 | 10:09 AM
yohon's Avatar
yohon
Follow up question though. If i wanted to run it further down the line could stock rods handle a small shot?
Last edited by yohon; Mar 24, 2017 at 10:10 AM. Reason: Posted 2 times by accident
Old Mar 24, 2017 | 11:13 AM
maxtor's Avatar
maxtor
If your engine is sound, and you proportion the correct amount of nitrous with gas, you should be fine with a 100hp shot of nitrous. Where people get into trouble is when the fuel delivery is not matched to the nitrous delivery.
Low fuel pressure, clogged fuel solenoid etc. Remember to retard your timing 4 degrees for a 100 hp shot.
Old Mar 24, 2017 | 04:20 PM
MIKES 68 F100
Extreme Lean = melted pistons
Old Mar 24, 2017 | 05:40 PM
yohon's Avatar
yohon
Great thanks yall
350on44s
22
Jan 24, 2010 06:10 PM
racer80
Dec 13, 2004 04:26 PM
Chewievette
Oct 24, 2004 09:55 PM
original67
May 30, 2004 10:38 PM
