2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Please bracket install impossible
Old Mar 22, 2017 | 03:47 PM
Junkgrab's Avatar
Junkgrab
My license plate front bracket fell off when I inched too close to a snow pile
I have tried every single rivet and none work since there is not enough room for the rivet to fasten. There is a solid metal plate behind the plast bumper. As per ford you are supposed to use plastic rivets so if the plate gets caught on something or like what happened to me with snow the rivets break and the plate bracket comes off rather than ripping your entire number off
So the rivets did their job but it is impossible to get another rivet in there since the metal fram or number is snug up against it
Pleas help can't drive with out a front plate
Old Mar 23, 2017 | 08:44 AM
neilster1's Avatar
neilster1
Nut, bolt and washer until you can solve the problem permanently. Maybe try a junkyard for a new bumper cover?
Old Mar 23, 2017 | 10:24 AM
rexster314's Avatar
rexster314
Are the holes in the bumper square?
There are replacement inserts usually at your local parts store. You push them in the holes, then attach the license plate with screws. I had to do this when I got a clear bra on the front end.
Old Mar 24, 2017 | 02:18 PM
Big's Avatar
Big
I went through this while trying to add a bumper plate to our 2010. I seem to remember the bumper had some dimples where the holes were supposed to be. Maybe that was another car. Anyway, I went to the trouble of buying the plastic rivets and a new larger rivet gun for said rivet and could not get them to work. There just wasn't enough room behind the bumper - because of the steel plate you mentioned - for the rivets to work. As I recall it would have taken major surgery to get things off to the point where I could have gotten that to work. OR there is some trick to it to make it simpler but I couldn't find anything on it.
So what I ended up doing is using some stainless steel driller screws that I had from a construction job site where I was working. I just drilled into the metal plate. It sounds hoopty but it went on really well. I didn't draw it down to the point where it would deform the bumper. And I check the tightness of the bracket often, and it hasn't loosened.
However, as they say, YMMV.
big
Old Mar 27, 2017 | 07:13 PM
mpgo4th's Avatar
mpgo4th
I put mine back on with self tapping screws. Can't see it once the plates back on it.
kctickbait
1983 - 2012 Ranger & B-Series
Apr 13, 2017 10:25 PM
ScriptTease
Jun 8, 2012 06:31 PM
KodiakF250
Mar 7, 2012 12:34 AM
is300wrx
2004 - 2008 F150
Jan 4, 2006 07:50 PM
smokey_and_freya
1997 - 2003 F150
Oct 15, 2001 05:06 PM
