Stalled no start
Old Mar 21, 2017 | 05:30 PM
yellowone's Avatar
yellowone
Stalled no start
Sorry if this was already covered.
I was towing a trailer about 600 miles truck was running great, pulled in for fuel and truck was running rough, refueled and was on my way then when going down a hill (Idle) it just quit, had to tow remaining 200 miles.
After reading the forums I replaced the ICR (ICR screen was damaged) Truck now starts but its very loud and missing like crazy. and surges if i give it a little gas. codes 0268, 0281, 2284, 2288 I also replaced the ICP.
Any Ideas?
should I replace the injectors? what causes this?
Old Mar 21, 2017 | 05:40 PM
2006powerstroke90's Avatar
2006powerstroke90
FICM voltage good?
Plugged in all the way?
Old Mar 21, 2017 | 06:00 PM
yellowone's Avatar
yellowone
FICM
YES 48 volts and 800psi when starting then fluctuates 1000-2500, I did see 8000 for a second when I first started it.
Old Mar 21, 2017 | 06:48 PM
Bumblebee04's Avatar
Bumblebee04
Oem fuel filters? And do you change them every 10k miles?
Be sure batteries are up to par by load testing them and make sure all connections are clean and tight. Including the grounds. Poltergeist emerges if the battery health is poor. Can you hear the fuel pump when you key on? Next would be to verify fuel pressure at the secondary fuel filter.
Old Mar 21, 2017 | 07:32 PM
bismic's Avatar
bismic
What year truck?
Old Mar 21, 2017 | 07:35 PM
bismic's Avatar
bismic
8000 isn't possible unless the pump (HPOP) deadheads and I don't believe that happened. I didn't think that the sensors would even report a value that high - even if sensor voltage went crazy.
I wonder if you don't have a short in an injector coil and your 5 volt reference circuit is being affected. Injector #3 is the one with the code for "short to ground".
Post vreference voltage.
Old Mar 21, 2017 | 09:39 PM
yellowone's Avatar
yellowone
2005 200,000 miles
about 10,000 on the filters
batterys are good, I made sure all the posts were clean.
i'll recheck the FICM connections
Old Mar 21, 2017 | 09:46 PM
Unluckiest's Avatar
Unluckiest
Trailering
Be sure the FIMC Snaps in!
Old Mar 21, 2017 | 09:51 PM
BLADE35's Avatar
BLADE35
dont forget this one
and did you replace icp pigtail
Old Mar 22, 2017 | 07:41 PM
yellowone's Avatar
yellowone
Don't see a vref on my autoenginuity scanner
Re-connected all the FICM connections and ICR and now truck won't start at all, it does try to start sounds like only two cylendars. only code now is the short on cylinder 3.
Truck wont run so im not sure if it fixed the 2284, 2288 codes.
No I did not replace the ICP pigtail looked good no oil.
I'll try again in the morning when the batteries are charged.
Thanks for everyone's help
Old Mar 22, 2017 | 07:47 PM
bismic's Avatar
bismic
still suggest addressing the above issue, and autoenginuity will read vref:
It may be called "calibration voltage reference input"
2 minute google search:
Help Needed - Won't start. Using auto enginuity | F-Series & SuperDuty Diesel Forums
Old Mar 23, 2017 | 08:43 AM
yellowone's Avatar
yellowone
I unplugged the # 3 injector now I get a low code. Still won't run.
Passes the buz test with exception to #3.
? If the ground wire on the Injector wiring harness went bad would that cause the problem?
Old Mar 23, 2017 | 09:47 AM
Unluckiest's Avatar
Unluckiest
Trailering
Been through a horrible similar ordeal with my husbands F350 06, 6.0. Check the electrical side of it very well.
After about a healthy black market kidney amount of work at a shop, was having the no start issue. We thought the FICM was bad, or just wasn't staying plugged well. Got it started, thought it would be ok, but it happened again, so he pulled the FICM off, worked with it all, put it back on, got the readings perfect, put the Turbo and whatever back on, it wouldn't start at all.
Took it all off again, got it all right, tried leaving it running while he put some of the stuff back on, it died. So he did it all again, he has a lot of patience this guy, and during that process it started, and sounded absolutely horrible, I thought it was done for.
He thought maybe limp mode or one side not firing, and decided then for sure that it was electrical somewhere. Kept plugging and unplugging to figure out wires in the harness, or the fuse box ,and then noticed that although that relay was sitting in there properly it was not seated right, the socket was bent.
He bent it back put the relay back and got it home.
Also, from reading and reading about this kind of problem I noticed that there is an emergency fuel shutoff switch, passenger door panel somewhere, and if something tore your screen that could be a big deal.
Old Mar 25, 2017 | 05:44 PM
yellowone's Avatar
yellowone
HELPPPPP!
OK here is the update:
Replaced injectors 3/5/7 Three had short, 5/7 has contribution errors.
Also replaced the injector wire harness, I was rough looking and the ground wire was frayed.
truck runs better but still have contribution code(P0281) calendar 7
Passes buz test I can hear all 8 buz now.
Also still getting P2284 code? Desired and actual are the same according to my AE.
Reference voltage is 4.98
Any Ideas?
Old Mar 25, 2017 | 07:48 PM
BLADE35's Avatar
BLADE35
you need to troubleshoot hpo system
rotun
Apr 13, 2015 11:23 AM
JW1971
Nov 12, 2014 10:16 PM
white cat
1983 - 2012 Ranger & B-Series
Dec 16, 2013 10:33 AM
mpbpulaski
Feb 16, 2012 03:56 PM
beemr
Sep 20, 2009 09:17 PM
