Front driver knocks/pulling
Old Mar 20, 2017 | 11:33 AM
daisydukke's Avatar
daisydukke
I got a horrible clunking/knocking in the front end of my pickup this morning, jerking the steering wheel like a flat tire, and after a couple miles it stopped..... bearing ???
Old Mar 20, 2017 | 11:41 AM
thomabb's Avatar
thomabb
What is it? Year? 4wd?
The front U-joints can do what you are describing when they seize.
Old Mar 20, 2017 | 11:44 AM
daisydukke's Avatar
daisydukke
It's a 2005 F150 4x4
Old Mar 20, 2017 | 12:46 PM
steve(ill)'s Avatar
steve(ill)
the 4 x 4 is disengaged by VACUUM.. If you get a leak in the hose, or the IWE is "sticking", you can get one front wheel stuck or partly engaged in 4 x 4.. disassemble and clean.. see attached post below.
Old Mar 20, 2017 | 12:48 PM
steve(ill)'s Avatar
steve(ill)
https://www.ford-trucks.com/forums/8...then-some.html
Old Mar 22, 2017 | 06:51 PM
daisydukke's Avatar
daisydukke
It has made some metal on metal clunking noise as well as progressively gotten worse as far as the jerking of the wheel. My upper control arm looks a little worn as does the bushing so I'm going to start with that and work my way to the u-joint....... thoughts???
Old Mar 22, 2017 | 08:19 PM
steve(ill)'s Avatar
steve(ill)
jack the front tires off the ground an inch with a floor jack under the lower A frame... With motor OFF, the wheel will be locked in 4 x 4.. if you try to turn it, the axle half shaft will turn, and the front drive shaft will turn.......... Start the motor, leave truck in park, and again try to turn the front wheel.. Should be DISENGAGED and in 2 x 4.. wheel will turn, axle and driveshaft will not.
Old Mar 27, 2017 | 09:31 PM
air1jpg's Avatar
air1jpg
I had a 2002 Ranger that did this when I turned the wheel while turning into my driveway and it was a control arm.
woopud
2004 - 2008 F150
May 25, 2019 09:41 AM
Italianhb68327
2004 - 2008 F150
Dec 9, 2015 05:14 PM
JohnyQ
Apr 2, 2015 09:05 AM
Gsong123
Nov 7, 2012 07:28 AM
otto
Dec 11, 2001 10:51 AM
