Steering.. UUGGGHHHHH....
Old Mar 19, 2017 | 12:07 PM
afonda's Avatar
afonda
Im getting ready to replace all the tie rods, steering box, etc... Found some good threads on the process...
Question is... is there some kind of u-joint in the steering shaft that needs to be replaced as well?
Also, are all the steering boxes reman or can you get new?
Old Mar 19, 2017 | 01:12 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I just replaced my steering box after it exploded internally and sheered one of the two bolt heads off the top. I did this at a campground with the help of Paul (AllAboutMPG) as the box destroyed itself just as I was parking the truck.
I would invite you to read through it as there is a lot of great information that would have caused the install to fail if I had not had it.
https://www.ford-trucks.com/forums/1...ering-box.html
Big thanks to FTE for the help and getting my family back on the road safely in short order.
As for remann or new, I believe most of the options are going to be remann, but you might be able to find something new if you are willing to pay for it.
RedHead has been a good option up until very recently. We have been seeing more and more failures from them, but it could be coincidental.
Joes Transmission in PA is a reputable shop that rebuilds steering boxes according some FTE brothers. https://www.facebook.com/Joestrans/
As for your steering shaft question, no there is no u-joint. There is a set screw where the shaft meets the gear box and then they come apart with a bit of prying toward the cab of the truck.
FordPickupTrucks
Feb 28, 2018 07:35 AM
bruno2
Mar 29, 2017 06:42 AM
glovemeister
18
Sep 24, 2013 09:00 PM
rob8210
Aug 2, 2008 06:27 PM
9wire
Jan 9, 2007 07:07 PM
