460 van conversion w/ e4od... aka money pit! ;'-(
Old Mar 19, 2017 | 02:05 AM
amockalypsenow's Avatar
amockalypsenow
Trans woes.
On trans number 3 in my e350 4x4 van.
I just put a replacement e4od in and it drove fine for a day, and shifted fine in all gears, but idled rough and so I spent about thirty minutes trying to troubleshoot the idle and when I went to drive it away, the trans would not engage unless the rpms were up around 3k!
No codes, trans fluid level fine, speedometer works, brake lights work.
What could it be?
Please help!
I'm tempted to just use this thing for target practice.
Thanks,
Cam.
Old Mar 20, 2017 | 10:15 PM
meborder's Avatar
meborder
i guess you might as well shoot it since you've already set it on fire ....
i'm sorry, i'm no help at all.
was this a used trans you installed?
nothing good makes it not engage until the rpm's are that high.
if i were guessing, i'd say #3 was bad before you installed it.
any kind of warranty or exchange possible?
if going to the trouble to install an unknown transmission, i'd seek out a transmission shop with a dyno that can verify that it is a good trans before installing it. most bigger towns should have at least one shop with a dyno if you call around.
food for thought.
Old Mar 21, 2017 | 07:54 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Have you replaced the coolers with each transmission? If not, when you install trans #4 it's going to fail, too. Bits of the old transmissions get caught in the coolers to be slowly released back to the trans, causing it to fail, too.
If it wasn't dead at this point, 3000 RPM to make it engage certainly killed it.
What could it be?
Something mechanical broke. It could be a seal, the pump, or a part of the rotating assembly. It's impossible to narrow it down to the exact part without a teardown.
djmarkh32
Jan 19, 2018 01:00 PM
NICKSAN
Aug 24, 2017 08:59 PM
msorros
May 6, 2014 04:12 AM
kickstarter
16
Apr 28, 2007 06:26 PM
