2000 Ford E150 Transmission Problem
Old Nov 5, 2013 | 01:53 PM
djmarkh32's Avatar
djmarkh32
My 2000 Ford E150 4.2L Van 155000Km the tranmission will go in reverse but when I put in Drive,2nd or 1st gear it does nothing anybody can help me out or ideas that would be great
Old Nov 5, 2013 | 03:16 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
My idea is that it's toast. Something mechanical inside the trans has failed. It needs to come out and get rebuilt. Sorry.
Old Jan 19, 2018 | 01:03 AM
yzyrpm1's Avatar
yzyrpm1
2000 Ford E150 4.6L Trans Problem
This is a Universal conversion Van bought new. Has only 70K miles on it.
I believe it has an after Mrkt Trans oil cooler on it, with rubber hoses connecting the lines into the radiator system.
One of those Trans hose's leaked bad, and Trans ran out of fluid.
Was going up a hill in town, Not highway, and Van stopped going forward. Backed down hill, and towed home.
Fixed with new hoses, put new fluid in, backed up and down short driveway a couple times, then let it sit and warm up for 15 minutes (was 0 out). Got back in, and no movement.
I do all my own Veh maint for some 50 yrs, but have never touched an Auto Trans.
Looking for a starting spot, from a knowledgeable Trans guy.Like...
check the Flux-Capacitor on the outside of trans.
Bottom line, looking for anything minor I can check on the outside of trans, or say under the trans oil pan, before I go the replacement route. Or some test I can try. I thought of towing it around the block, running and in drive, to see if that would *prime* the pump. Yes, layman's term and thought, have no idea really how Auto Trans work, other than I assume via pressurized fluid turning gears?
Any suggestions, sites to visit, are welcomed. Thanks, Roger
I hope replys come back to my EMail: yzyrpm1@yahoo.com
Old Jan 19, 2018 | 08:07 AM
jbwheels's Avatar
jbwheels
Excellent! Another question where I know just enough to be dangerous.
The pump runs when the engine runs so no priming it. Towing a modern automatic will do more harm than good because the pump isn't running but everything is turning.
If you were driving uphill with no/low fluid, the clutches and bands are toast at the very least. Maybe the pump and converter, too. Basically anything that moves and depends on the fluid for lube and cooling could be damaged - severe wear and/or overheated.
Internal damage. Time for a rebuild.
Old Jan 19, 2018 | 09:04 AM
Mark Kovalsky
Does it have enough fluid in it? If it isn't low, the transmission is done. Pull it out and rebuild or replace it.
Old Jan 19, 2018 | 12:32 PM
yzyrpm1's Avatar
yzyrpm1
Thanks Guys. Guess it's time to pull out the CC.
You need to be congratulated for your help to us novices.
Old Jan 19, 2018 | 01:00 PM
vettex2's Avatar
vettex2
towing it correctly won't hurt a thing (rear wheels on a dolly or disconnecting the driveshaft or lifting the rear wheels off the ground)
towing it incorrectly and you are 100% correct
Aerostar65
Aerostar
Dec 30, 2009 10:24 AM
tjwc1
Jan 24, 2009 04:45 PM
WorkVan58
Aug 4, 2008 07:28 AM
TallPaul
Aerostar
Nov 2, 2002 01:28 PM
Racerguy
1997 - 2003 F150
Oct 18, 2002 08:35 PM
