Turning Off Reverse Beeper
Old Mar 18, 2017 | 05:46 PM
Laconia Excursion's Avatar
Laconia Excursion
I just took delivery of my first ever 2017 Ford F-250 Platinum truck. What a machine. I ordered the reverse beeper and wanted to only use it when i am trailering. It is so loud, it could wake the dead. I was told by the dealer that i can turn it on and off when i want. I have looked everywhere. Does anyone know if this can be done and how? Thanks in advance for your help.
Old Mar 18, 2017 | 07:03 PM
Davydee's Avatar
Davydee
On our truck, when you put it in reverse, a screen comes up in the information screen asking if you want parking assistance on or off. I can't speak for others, but I've found it convenient. David
Old Mar 18, 2017 | 07:49 PM
bluewaveaudio's Avatar
bluewaveaudio
thanks, I've never found the way to turn it off, ill try that tomorow
Old Mar 18, 2017 | 07:53 PM
Laconia Excursion
I think you are referring to the "Parking Assist", this is not that. It is the beeper that sounds when you put the truck into reverse, it was an accessory. It is like when a cement truck backs up. Before it moves, the beeper is going on and off rhythmically.
Old Mar 18, 2017 | 10:31 PM
lifelineamb's Avatar
lifelineamb
Crawl under and see how it's wired. If it's just wired into the reverse lights you will have to rewire it to an upfitter switch or something similar. typically the backup alarms are simple two wire setups however, on my fleet vehicles (ambulances) there is an aftermarket momentary switch that disables it upon shifting into reverse, the alarm will sound again only if the vehicle is taken out of reverse and then put back into reverse. Perhaps the dealer can offer you more specific info on your application.
Old Mar 18, 2017 | 11:17 PM
Blubld's Avatar
Blubld
It's funny I'm reading this. I picked up my new 250 yesterday and found out mine was accidently ordered with this backup alarm. I searched online but could only find answers to older super duties, nothing reference 2017.
What I learned between online and from the techs at the dealer: you can't turn it off. If you don't want it to sound the only option is to unplug it at the siren. It is located just behind the rear axle on the drivers side up against the bottom of the bed. It was easy to access and unplug. There was a post I read, from this site if I remember right, about someone running a wire to a toggle for it. Do some research, maybe it would work with our upfitters.
I've lurked on here for months. I feel bad for you and your issue given I just struggled with it yesterday so it forced me to join finally.
Old Mar 19, 2017 | 06:36 AM
Tedster9's Avatar
Tedster9
Maybe can stuff the element with a rag or something. The alarm isn't such a bad idea it just doesn't need to be so loud as to be audible from six blocks away.
Old Mar 23, 2017 | 07:33 PM
Davydee's Avatar
Davydee
You're correct, what I'm seeing is called "parking aid". Get the screen asking whether I want to leave it on or turn it off whenever I put our truck into reverse. Selecting Off stops that annoying tone in the cabin when hooking up to the trailer. On thing I have noticed: If I select "On" accidentally, there's no turning that tone off no matter what I do.
David
jimmystoys
6.7L Power Stroke Diesel
Jun 16, 2013 11:44 AM
FONRDAY
Aug 12, 2012 11:09 PM
ponyrider
Escape & Escape Hybrid
Dec 7, 2008 09:20 AM
jinserra
Jul 26, 2006 10:12 PM
Rockafella
Feb 15, 2003 09:09 PM
