Door Panel
Old Sep 24, 2003 | 05:47 PM
Fal Grunt's Avatar
Fal Grunt
Door Panel
Im going to remove the plastic door panel on the right door. However I cannot get it off. I got the left off, theres screws...... but tyhe right I can't get off. I want to get them off so I can replace the speaker which doesn't work. thanks -myers
Old Sep 24, 2003 | 06:20 PM
Torque1st's Avatar
Torque1st
Posting Legend
Door Panel
They both come off the same way unless someone has messed with them and changed fasteners.
Old Sep 24, 2003 | 06:30 PM
derek_seli's Avatar
derek_seli
Door Panel
with mine you just take off the door handle, window crank, and plastic handle in the armrest. then there are snap type fasteners that snap onto the door. You should be able to pull or pry the panel off.
You say the left was held on by screws? I assume a previous owner must have broken the panel where the clips are so he just screwed the panel on.
Old Sep 25, 2003 | 12:20 AM
460f250's Avatar
460f250
Mine had a couple screws kinda hidden inside the map pocket. Where does it hang up?
