General braking question
Old Mar 18, 2017 | 12:08 PM
79 F-150 Stone's Avatar
79 F-150 Stone
I have a 79 F150 which I am hoping to fix up one more time. One issue that has always been a concern is braking, I have been told to put a hydra booster in it but I haven't looked into the cost. I drive this truck about 2000 miles per year and I don't plan to make it a daily driver so I am limiting how much I spend on the fix-up.
My mechanic tells me this truck never had good enough braking to begin with and I'd like to know what you guys think. It weighs 5500 empty and it came with small front discs and rear drums, which is why he said what he did.
Old Mar 18, 2017 | 02:13 PM
LittleBlue79's Avatar
LittleBlue79
It weighs a ton and has tiny brakes, what can you really expect?
As far as hydroboost goes, I haven't done that to my Dent, I did do it on my XJ rockcrawler and it made a huge difference.
This is the thread that I am going to reference when I find the parts to do the conversion.
https://www.ford-trucks.com/forums/8...sion-done.html
It has the years and models that will most likely have the setup in it. As well as a step by step for the install.
And here's a little something I copied from that thread
"Stock brake system
60mph-0mph 258 feet
HydroBoost
60mph-0mph 164 feet" Seems well worth it to me.
Old Mar 18, 2017 | 02:58 PM
HIO Silver's Avatar
HIO Silver
Old Mar 18, 2017 | 05:09 PM
Blue and White's Avatar
Blue and White
I wonder how the brakes work now and what the issues are? Are the brakes power assisted now?
Front discs/rear drums can work pretty darn well if everything is in shape... I'm not sure I agree with your mechanic.
Old Mar 18, 2017 | 06:18 PM
Filthy Beast's Avatar
Filthy Beast
Agree with Blue and White.....and I'm sure I don't agree with your mechanic.
2K miles a year is not enough to keep the brakes in good working order. The brake fluid can sour, rubber parts can crack/become brittle, and leak, the booster diaphragm can get brittle and not hold a vacuum, etc.
If your M/C is good = no leaks, internal or external, the brake fluid is clean, the booster diaphragm doesn't leak and the booster rod is correctly adjusted, your lines don't leak and fittings are tight, the pads/rotors are good as well as the shoes/drums...well, you've got everything working right.
These vehicles stop better than '67 - '71 Mopar boats with better pedal feel.
Old Mar 18, 2017 | 06:37 PM
Los_Control's Avatar
Los_Control
I agree with the beast on this one.
If you have a fully functional good working brake system, it would be adequate for normal usage.
If you want to race this truck and build the motor, you need to increase the brakes.
If you want to pull a heavy trailer, you want to increase the brakes.
But for a average user the brakes are just fine as they are.
But they do need to be in good working condition as any brakes on a vehicle should be.
Old Mar 19, 2017 | 12:44 AM
PapaBearYuma's Avatar
PapaBearYuma
The truck may not have the best braking system ever created, but...
It's good enough. Don't overload it, and be aware of your stopping distances. One of the most important things I remember from driving school, right after "don't outdrive your headlights" is "don't outdrive your brakes"
Old Mar 19, 2017 | 08:02 AM
79 F-150 Stone
All good points! It's clear this truck has limited braking and I will do all the basics to get the best I can get. It's difficult to go from today's driving habits where a truck this size would have twice the braking capacity, in the form of much larger discs on front and rear, to driving so cautiously.
It just sucks because it rides much better with 1500 pounds in the bed because of the stiff shocks, but you have to drive it so cautiously.
But......the bottom line....... she's a classic and I love her So just like any woman.......proceed with caution
wotan
16
Jun 26, 2013 09:14 AM
Jermafenser
Apr 6, 2007 10:32 AM
Munky
1997 - 2003 F150
Feb 1, 2007 09:27 AM
jozs56ford
Feb 6, 2004 01:59 PM
seans64'
Oct 23, 2003 12:40 AM
