Help! Brake problem
Old Mar 18, 2017 | 02:06 AM
BULLDOG-X04's Avatar
BULLDOG-X04
Help! Brake problem
Hello everyone. Need some help.
So I pulled the righ front wheel from my 2000 X, 6.8 V10. Noticed there is a tube running g to brake cylinder that's nearly broken off. The other end is hanging on by a thread. See pics for details.
Any my ideas what this is? Front brakes shutter too but that may be bad rotors? Thanks in advance!​​​​​​​
The far right hose
Old Mar 18, 2017 | 02:09 AM
BULLDOG-X04
Oh and the ABS light is on. Maybe that's related?
Old Mar 18, 2017 | 06:57 AM
moe67moe's Avatar
moe67moe
Isn't that the vacuum line to activate the 4 wheel hub?
Old Mar 18, 2017 | 08:37 AM
Blakshukvw's Avatar
Blakshukvw
Yes. Your hubs won't engage with that hose broken. It supplied vacuum too the hub.
Old Mar 18, 2017 | 10:27 AM
projectSHO89's Avatar
projectSHO89
Look closer. It doesn't go to the brake system.
Old Mar 18, 2017 | 11:15 AM
BULLDOG-X04
Great thanks everyone.
So so what is this part called? 4wd vacuum tube?
Old Mar 18, 2017 | 11:51 AM
Apocalypse's Avatar
Apocalypse
ESOF tubes, go with the braided ones for the extra HP
Braided 4WD Electronic Shift on-the-fly Replacement Lines | SuperMotors.net
Old Mar 18, 2017 | 12:06 PM
projectSHO89
It's called a rubber hose.
Old Mar 18, 2017 | 02:01 PM
Apocalypse's Avatar
Apocalypse
Technically yes, but it is an ESOF hose. If the guy at the parts store asks what he needs it for he can't say "a rubber hose", but he can say "to replace the obvious flaw ford left in my esof system... the esof hose."
Old Mar 18, 2017 | 02:57 PM
BULLDOG-X04
Perfect! Will get that hose. Many thanks!
Old Mar 18, 2017 | 06:08 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
The hose you buy should be 1/8" inside diameter. Just like the vacuum lines on the rest of the truck. This is what I use. Lasts a lot longer.
Amazon Amazon
96F150-4.9
Jan 12, 2019 05:03 PM
bfwellington
1947 and Older Ford Trucks
Apr 22, 2015 10:10 PM
kraylake
Jan 5, 2012 10:54 AM
afreemanmd
Aug 2, 2010 05:38 PM
pohlmeyr
2004 - 2008 F150
Jan 4, 2009 09:07 PM
