Camper package pigtail charging
Old Mar 15, 2017 | 09:20 AM
nathan_2017's Avatar
nathan_2017
I was talking with a buddy who has a F150, he said he has the towing package but it does not have the feature to charge his camper battery through the pigtail connection when driving.
I have the camper package on my F250 and was wondering if it would have this feature. I tried looking it up with no luck. Ford's site only talks about the suspension upgrades.
Thanks for the help
Old Mar 15, 2017 | 09:25 AM
GoDuke1's Avatar
GoDuke1
You have it. Once you plug in your trailer and press the brake & trailer brake it will activate and start charging. When you first plug it in it will not start charging but once your on your way it kicks in.
Old Mar 15, 2017 | 09:48 AM
mhoefer's Avatar
mhoefer
If you want the 7 pin plug in the box, then you need the fifth wheel prep as well. Unfortunately, the camper prep package doesn't include the 7 pin trailer plug in the box. The harness for that has a part number if you wish to add after. It plugs into the tailgate, bumper plug harness.
Old Mar 16, 2017 | 01:22 PM
saikk's Avatar
saikk
I didn't think about this on my order. Do you have the part number for that harness and a rough guess on how much it would be? With the bed plug added, can one can still tow a trailer with the 7 pin plug in the bumper. (Plug a slide in camper into the bed plug and connect a boat or atv trailer in my case).
Old Mar 16, 2017 | 06:16 PM
marobrown's Avatar
marobrown
Your buddies f150 may need a relay installed in the fuse panel to enable the 12 volt charge feature on his 7 pin connector. I had to with mine.
Old Mar 16, 2017 | 09:11 PM
CGA's Avatar
CGA
HC3Z-15A416-A
Kit - Trailer Hitch Electrics
$81.20 online
It plugs into standard harness so they both work. Kit has everything you need. You will have to drill a hole in the bed.
Old Mar 16, 2017 | 09:57 PM
WYflyfisher's Avatar
WYflyfisher
When our truck arrived at the dealer, they installed the plug where we needed it in the bed -- cost about $160 to have it done. They also added the airbags and Torklift tiedowns. However, it may have been easier to work with this dealer because they also sell truck campers. So when we picked up the truck, everything was done.
Old Mar 16, 2017 | 11:52 PM
mhoefer's Avatar
mhoefer
UCGA got you covered.
Old Mar 17, 2017 | 12:44 PM
saikk's Avatar
saikk
Thanks guys
Old Mar 17, 2017 | 01:48 PM
nathan_2017
Thanks for the info
Old Mar 17, 2017 | 10:02 PM
GoDuke1's Avatar
GoDuke1
Originally Posted by nathan_2017
Thanks for the info
Learned the hard way! Hooked up for the first time and had no juice. I looked up the fuse and relay. Fuse was easy enough to find, but the relay was next to impossible. There was a reason it was hard to find. It didn't exist nor was it needed. After searching here I found my answer.
binuya
Jul 1, 2014 02:00 PM
F350blueberry
6.7L Power Stroke Diesel
Jul 30, 2012 10:05 PM
ProActive
All Things Towing
Aug 4, 2009 11:35 AM
jonesg
Mar 22, 2008 09:40 AM
FKNVA
1997 - 2003 F150
Jun 16, 2003 09:10 PM
