5th wheel prep
Old Jul 30, 2012 | 06:41 PM
F350blueberry's Avatar
F350blueberry
5th wheel prep
What happens if I use the plug for the 5th wheel prep package to plug in my slide in camper ? Can I still use the rear plug for a trailer ?
Old Jul 30, 2012 | 06:55 PM
Specularius's Avatar
Specularius
Works great for me. I did have to make an extension for my truck camper and the supertruss has an extension on it for the trailer.
Old Jul 30, 2012 | 07:22 PM
sdetweil's Avatar
sdetweil
I think all you get is power & ground.
Sam
Old Jul 30, 2012 | 07:42 PM
F350blueberry
This was my plan to get an extension and just plug my camper into the plug in the bed. Then use the rear plug for a trailer. Just wondered if this would confuse the truck by having 2 things plugged in at once.
Old Jul 30, 2012 | 07:48 PM
Specularius
No confusion and all marker lights and turn signals work correctly as well as the battery charge circuit for the truck camper.
Old Jul 30, 2012 | 07:51 PM
RV_Tech's Avatar
RV_Tech
In essence you would be doing the same thing if you added lights to your trailer or to your truck camper. The circuits should be hot, but the power will be finite. There is a limit to how much power can be carried down wires to the rear, but folks pull trailers behind truck campers all the time and fifth wheel owners pull boat trailers without much trouble.
Steve
Old Jul 30, 2012 | 09:48 PM
F350blueberry
Thanks. Sounds like it should work just fine.
Old Jul 30, 2012 | 10:05 PM
sdetweil's Avatar
sdetweil
Steve
Right. Usually when you are towing, nothing is going on in the camper and vice versa, so only or load at a time.
Sam
DVSF350
Aug 29, 2022 07:51 AM
nathan_2017
Mar 17, 2017 10:02 PM
ProActive
All Things Towing
Aug 4, 2009 11:35 AM
jmcder53
All Things Towing
Jun 14, 2008 06:57 PM
fyrhog
Sep 12, 2005 08:42 PM
