door gaps
Old Mar 14, 2017 | 11:22 AM
jrockdiddy's Avatar
jrockdiddy
door gaps
whats the going size for door gaps these days? door/cowl is about 1/4", and rear door/cab is about 1/8". But, door/cowl when i open the door, the door gets really close to the cowl, curious if paint will get chipped after filler, primer, and paint... I'm trying to attach a video.
Old Mar 14, 2017 | 12:08 PM
jrockdiddy's Avatar
jrockdiddy
video posted
Old Mar 14, 2017 | 02:14 PM
jrockdiddy's Avatar
jrockdiddy
Nobody?
message tooo short
Old Mar 14, 2017 | 02:24 PM
schoo's Avatar
schoo
use a paint stick mine are from one stick too two sticks wide
Old Mar 14, 2017 | 04:58 PM
CharlieLed's Avatar
CharlieLed
3/16ths is the correct gap
Old Mar 14, 2017 | 06:16 PM
jrockdiddy's Avatar
jrockdiddy
Charlie does your gap get tighter when you open the door?
Old Mar 14, 2017 | 09:50 PM
CharlieLed's Avatar
CharlieLed
Not sure what you mean...the gap gets wider as I open the door, otherwise I wouldn't be able to get my fat a$$ in the truck. I think you might be referring to the gap between the front edge of the door and the cowl...that gap is not one that I have paid much attention to, if the door swings freely then all is good.
Old Mar 14, 2017 | 10:46 PM
jrockdiddy's Avatar
jrockdiddy
In the video I posted, when I open the door, the cowl/door gap gets slightly more narrow, then opens.
Old Mar 15, 2017 | 12:35 AM
CharlieLed's Avatar
CharlieLed
Sounds normal...shouldn't be a problem unless you really slather the filler onto the cowl and really close up the gap.
Old Mar 15, 2017 | 08:45 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Nice BBW Charlie.
Old Mar 15, 2017 | 11:00 AM
Connecticut Calvin's Avatar
Connecticut Calvin
Unhappy
You're correct. When I got the bottom half of the original cowl cut out and welded in the bottom half of a new panel from LMC I had a small spot weld that stuck out maybe 1/32" further than the rest in that little channel where the door rests into. It looked fine when the door was closed but the door and the weld connected when I opened the door after painting. It pinched the cowl panel and scraped off my nice new paint job. Let's just say that a raised 1/32" weld was a costly mistake. I had to remove the door, grind down the weld a bit, put on bondo to clean up my crappy weld job and grinding job, sand that, prime it, sand that, airbrush that small section with my Eastwood metallic SSU and reattach the door. It was a major headache. Charlie is correct 3/16" is about right. NO LESS! When closed your door seems much too tight.
Old Mar 15, 2017 | 12:10 PM
jrockdiddy's Avatar
jrockdiddy
When my door is closed, I have 1/4". Don't let the video fool you. It's from an angle, not directly perpendicular to the door. I was trying to show the gap when the door opens slightly
Old Mar 15, 2017 | 12:11 PM
jrockdiddy's Avatar
jrockdiddy
https://goo.gl/photos/UrDMkbpCL6VcybR37
Try this. Don't mind the green circle
BrandonT71
Jun 18, 2013 03:56 PM
adios pantalones
Feb 19, 2012 07:35 PM
freejay
2004 - 2008 F150
16
Jun 22, 2009 12:07 AM
79CEEJAY
Sep 16, 2002 04:05 PM
