Aux Power location
Old Mar 12, 2017 | 04:31 PM
Goncutn's Avatar
Goncutn
Aux Power location
I have a 2017 F350 Diesel, I'm installing a 2 way radio and tried hooking the power wire up to a spare location in the interior fuse panel in a fuse port that was called "spare" in the manual. The fuse that I pulled from the panel was actually the circut for the shifter/brake release function. Do not have the upfitter switches so I'm hunting for another hot location to attach the positive wire for the 2-way radio. It has to be hot at all time as I need it on. Any one find a hot location to go to, other then going all the way to the batteries?
Old Mar 12, 2017 | 05:52 PM
System's Avatar
System
Prolocutor
The 10 gauge power line to the inverter under the back seat is always hot. Otherwise, it would be easy enough to use the factory supplied firewall pass through wires above the passenger kick panel to shoot a line directly to the battery.
whporwil
6.4L Power Stroke Diesel
Sep 8, 2009 03:01 PM
mlevario99
Sep 5, 2008 08:20 AM
joenoll
2004 - 2008 F150
Jun 19, 2008 07:37 PM
ejolliffe
Aug 15, 2007 07:45 AM
Joe Boz
Electrical Systems/Wiring
Mar 2, 2005 11:11 PM
