Electrical Problems on 1990 Supercab
Old Feb 28, 2005 | 01:01 AM
Joe Boz's Avatar
Joe Boz
I am fixing up a 1990 F-150 Supercab for my son. We recently installed an after market AM/FM/CD player along with a power amp. The new sytem was installed using the wiring from the old stock stereo. For the constant hot wire on the stereo I ran a wire to the fuse panel. For the amp I ran wires to both the positive and neagative post on the battery. For some reason now my power windows and windshield wipers will work without the use of the key. Is there a short or are my wires crossed?
Old Feb 28, 2005 | 05:36 AM
trike1946's Avatar
trike1946
What did you hook the wire to in the fuse panel?
Old Feb 28, 2005 | 06:24 PM
Franklin2's Avatar
Franklin2
Take the constant hot wire off that you added for the stereo, and see if your window problem goes away.
You should not have needed to run a seperate wire for the constant hot, the factory radio should have had a constant hot wire already up there behind the radio.
Old Mar 2, 2005 | 11:09 PM
Joe Boz's Avatar
Joe Boz
Exclamation
Thanks for ya'lls imput. I eliminated the constant hot to the fuse panel and re-wired the stereo. eliminating the constant hot to the fuse panel fixed the power window problem. But i still have a short somewhere. I keep blowing fuses that concern the radio and the parking/running lights. Any thoughts? Thanks from Mississippi
Old Mar 2, 2005 | 11:11 PM
Franklin2's Avatar
Franklin2
If it only started blowing fuses after you installed the stereo, I would double check your wiring again.
dae06
1983 - 2012 Ranger & B-Series
Dec 29, 2011 10:56 PM
jssf24
2009 - 2014 F150
Aug 20, 2010 05:01 PM
vqarabs
Electrical Systems/Wiring
Apr 20, 2008 01:27 PM
Strait_ap
1978 - 1996 Big Bronco
Jan 16, 2004 07:08 PM
angreczyna
Dec 24, 2002 12:22 AM
