Adding a battery
Old Mar 12, 2017 | 03:41 PM
bigcountry1009's Avatar
bigcountry1009
Adding a battery
I'd like to add a battery to my stock trailer to power LED interior lights. Do you think the 12volt feed on my 7 blade harness will keep it charged?
Old Mar 12, 2017 | 04:55 PM
RV_Tech's Avatar
RV_Tech
That depends on your power consumption. How many hours of on time, how many lights, and how much time will your engine be running so the alternator is putting out, but my first thought would be just try it and see. It won't hurt anything and I suspect you will be fine.
Steve
Old Mar 12, 2017 | 06:22 PM
bigcountry1009
All I plan on running from that is a 16 foot roll of that LED strip lighting for interior lighting.
Old Mar 13, 2017 | 04:50 PM
seventyseven250's Avatar
seventyseven250
Well, your LED strips should have a watts/foot rating, so you can get a pretty good idea of what your power draw will be. How many hours/day and for how many days between driving/recharging do you think you'll be using them?
Probably fine, but if you like numbers, that's the kind of thinking you should start with.
Old Mar 13, 2017 | 05:13 PM
Chuck's First Ford's Avatar
Chuck's First Ford
I have a 16 foot LED type on the outside of my Travel Trailer...
12 volts, direct power... ( No converter )... it will draw 3 amps
Read the one you get.. to know for sure.
Old Mar 18, 2017 | 11:27 AM
JakeHan's Avatar
JakeHan
Have a lashup similar to that, a deep-cycle battery on a trailer to run a fuel pump (WAY more draw than what you're doing). Seems to work fine, as long as there's enough run-time between tanks of fuel to charge it back up. There is some voltage drop, but not much, the circuit's still well over 12v at the battery - heavy gauge charge wire helps the drop. Big thing is to remember that you have a hot wire in the trailer plug all the time - I have thought about rigging mine on a relay or diode or something of the sort to kill it when you unplug from the pickup, but haven't done it yet.....
V10man
All Things Towing
16
Jan 11, 2015 06:46 PM
SlickYamaha
Feb 25, 2012 09:27 PM
apollo3519
1997 - 2003 F150
Jan 23, 2010 10:24 PM
Joeymt3
Dec 17, 2008 03:45 PM
V10Crew
Oct 13, 2008 02:16 PM
