Transmission or transfercase
Old Mar 12, 2017 | 11:22 AM
Shawn Ertl's Avatar
Shawn Ertl
So I recently purchased a 1994 F150 4x4 5.8 w/ AODE transmission 140 ish miles. Truck will not go into any gear except 4L drive/ no reverse
1) previous owner took it to a shop and they said it could be a Torque converter issue- original diagnosis it would not go into reverse
When I got it there was no reverse and was trying to go forward but failed and stalled- at first had issues getting the transfer case into neutral.
Once I got it home I experimented with it, putting it into 4L the truck was able to move forward but no reverse. Outside of that no other movement.
I have read several articles saying it could be the transfer case and some saying it could be the transmission.
anyone run into this or suggestions?
Old Mar 12, 2017 | 11:34 AM
Nothing Special's Avatar
Nothing Special
It sounds like trans to me. Putting the transfer case into low range puts less load on the trans, so a marginal trans is more likely to drive with the t.case in low than with it in high. But the problem is that the trans won't drive.
F-150 MP
Modular V8 (4.6L, 5.4L)
Jul 30, 2015 08:05 PM
blacklabcaleb
Jun 25, 2013 11:52 AM
gunnerw
Mar 26, 2012 10:35 PM
fireeater91
Feb 23, 2007 04:31 AM
ilbigmike
Jul 2, 2004 07:21 AM
