Sponsored by: Auxito
Engine fit question
Old Mar 10, 2017 | 01:42 PM
Swj's Avatar
Swj
Engine fit question
Hello all!
Thank you for a great site. I have a 2000 F150 with about 150k miles. It has smashed the valves on the drivers side, due to an unfortunate incident with the timing jumping. So Ive been looking around and found a 97 f150 with a newer motor (47k) for very cheap. The only problem is that truck is a 5 spd, and mine is an automatic. Is there any reason the motor from the 5 spd would not work with my auto? Thanks
Old Mar 10, 2017 | 01:43 PM
Swj's Avatar
Swj
Originally Posted by Swj
Hello all!
I should probably add that they are both 4.6s.
Old Mar 10, 2017 | 02:21 PM
enriched&beyound's Avatar
enriched&beyound
Hello all!
Things should swap in just fine.
Things to check/find out with your potential replacement engine. Was that 97' engine upgraded to PI heads?
You will probably need the flywheel off you old engine and maybe extract the pilot bushing from the crank shaft of the donor.... & maybe swap out some sensors... other than that it should bolt up.
Old Mar 10, 2017 | 02:36 PM
Swj's Avatar
Swj
Ah yes, I should find that out, as it supposedly was a reman from 2012. Since my original motor doesnt have PI heads (i dont think?) Would I need a new computer or anything? I also wonder what else I would have to purchase to perform this swap.
Old Mar 20, 2017 | 02:02 PM
01 GT F150's Avatar
01 GT F150
The other thing to consider is if it's a windsor or romeo 4.6. different amount of bolts on the crank for the flex plate. romeos have 11 bolt valve covers and windsor's have 13.
Jimmy Krizan
Jan 9, 2019 01:31 PM
matohunter
1997 - 2003 F150
Jul 21, 2010 08:18 PM
jbrabeck
1997 - 2003 F150
Oct 14, 2009 07:07 AM
unclebeau
1997 - 2003 F150
Jan 7, 2007 12:54 PM
raymond47
Aerostar
Oct 19, 2004 03:58 PM
